I'm having a problem getting the new student version of 3ds max to download properly. The download usually starts up fine, but three to ten minutes into the download it claims its finished, yet when I try to install I get a pop up saying file has been corrupted. I've disabled firewalls, tried differnt browsers and still the same thing. I have enough space on my hard-drive also. As a side note I've installed 2011 before and never had a problem.
Oh! That was a clever idea -- I'm having the same issues with the Student version.
Where/how did you download and activate the professional version, please?
http://usa.autodesk.com/adsk/servlet/download/item?id=17521273&siteID=123112
As long as you have an activation code for your student edition you just put that in.
The 2011 version of the program 3Ds Max for students, has a problem in the download file and can not install it.
Please change the file or upload it again.
Hi alexislarrahona,
We have had some download issues in our EDU site, please refer to this link: http://autode.sk/OKbrGd for some troubleshooting steps.
If you still cannot download successfully, reply to this thread and include a screenshot of the error or the error message if any.
Hello!
The error persists, so I made a little video that shows the error.
When I'm extracting the "zip" file, errors appear:
"CRC error in support / Partners / CraftAnimations / CraftDirectorStudio.exe" The file is damaged
Unexpected end of file.
Here the video:
Hi alexislarrahona,
For CRC errors like the one you encountered, please do check your internet connection, firewall and antivirus.
Do the following prior to download:
- Disable antivirus
- Download on a different network or on a different machine with a different browser
Alternately, you can use a different download method from here: http://autode.sk/qrls3M.
Thank you very much!
I tried downloading the file from another computer and disabling antivirus, using a different browser, and I can normally extract it.
