Installation & Licensing
Message 1 of 9
684 Views, 8 Replies
Strange error
I'm getting a strange error message when I try and install the 2015 version of AutoCAD. The error I speak of is 'Entry point not found: C:\Autodesk\AutoCAD_2015_English_32_64bit_R1_wi_en-us\Setup\LiteHtml.dll.  Can someone help me plsease?
8 REPLIES 8
Message 2 of 9
asburyj
Hello Kinsey and welcome to the forum,
Take a look at the solution linked below for that litehtml.dll error and give those solutions a try.
http://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/The-Program-errors-when-I...
Jeffry Asbury
Message 3 of 9
in reply to: asburyj
I tried the first solution and still get that error andthe second solution doesn't make sense to me.
Message 4 of 9
asburyj
For the second solution can you try just ignoring the othert steps and try this part only ?
  • Right-click  Setup.exe, go to Properties,  select the Compatibility tab, select "Windows XP (Service Pack 3)."
Jeffry Asbury
Message 5 of 9
I should  have mentioned that I have Windows 8 on my Laptop which is where I'm trying to install it on. I have already downloaded both the Browser Download and Download Now for 2015.
Message 6 of 9
asburyj
I understand, you are choosing the compatibility mode to try to work around the error you are encountering.
Jeffry Asbury
Message 7 of 9
Ok. I'll try it later.
Message 8 of 9
Hi, I have the same exact problem. I followed what you said, but it still didn't work. I'm also quite confused by the first solution. Where do I find these Windows C++ components? Where are they located on my computer?
Message 9 of 9
asburyj
Yes the Microsoft Visual C++ versions are on your computer. If you load your programs and features control panel you should see a list of them. If you opt to uninstall and re-install them they can be re-installed from the links below. Note: 64 bit OS types need both the x86 and x64 versions installed.
Microsoft Visual C++ 2005 SP1 Redistributable Package (x86)
http://www.microsoft.com/en-us/download/details.aspx?id=5638
Microsoft Visual C++ 2005 SP1 Redistributable Package (x64)
http://www.microsoft.com/en-us/download/details.aspx?id=18471
Microsoft Visual C++ 2008 SP1 Redistributable Package (x86)
http://www.microsoft.com/en-us/download/details.aspx?id=5582
Microsoft Visual C++ 2008 SP1 Redistributable Package (x64)
http://www.microsoft.com/en-us/download/details.aspx?id=2092
Microsoft Visual C++ 2010 SP1 Redistributable Package (x86)
http://www.microsoft.com/en-us/download/details.aspx?id=8328
Microsoft Visual C++ 2010 SP1 Redistributable Package (x64)
http://www.microsoft.com/en-us/download/details.aspx?id=13523
Microsoft Visual C++ 2012 Redistributable Package (x64)/(x86)
http://www.microsoft.com/en-us/download/details.aspx?id=30679
Jeffry Asbury
Tags (1)
Administrator Productivity
