Installation & Licensing
Strange - Autocad Install cancelled.
3 REPLIES 3
larry11
1842 Views, 3 Replies
I am not sure what is happening with the ol' 32 bit desktop.I received some links from the Autodesk Business Center for direct downloads for my 2013 Revit Architecture Suite. I recently cancelle my subscription, but learned that I was entitled to the 2013 release.
After initialization, I run the install and it goes all the way to the final screen (like 30 minutes later), and then I keep getting the following error message "Installation was canceled. Some products were not installed." Please refer to the attached screenshot when I tried Autocad 2013.
Really frustrating that it keeps running to the end of the install process, just to give me this screen no matter which part of the suite that I try.
Would appreciate your thoughts.  I cannot find anything in the forums, but I am kinda a newby.  Thanks very much.
-LBLII
3 REPLIES 3
TravisNave
in reply to: larry11
Post your installation log file from your %TEMP% folder.  It may have some insight to the failure.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
larry11
in reply to: TravisNave
TravisNave,  After I intalled the Windows Updates, it worked.  Thanks for posting anyhow.  Best.
-LBLII
naresh_kalyan
Administrator Productivity
