Installation & Licensing
New Member
vividanimations
Message 1 of 3 (1,604 Views)
Still can't uninstall the 32 Bit Object enabler
1604 Views, 2 Replies
02-27-2013 12:16 PM
Help link presented in Control Panel doesn't work, and I can't reinstall the files so it has whatever it needs to uninstall itself because I have a 64 bit computer. Anyway, I've been at this for hours and I basically have given up, so I'm just going to repost my first question below.
I'm trying to re-install 3ds Max 2013, but because I messed up on the installation the first time, I first have to remove all the Autodesk products on my computer. There is a certain peripheral "AutoCAD Civil 3d 2012 32 Bit Object Enabler" that presents me with the following message every time I try to remove it: "Error 1606. Could not access network location 0."
Does anyone know what I should do?
Edited by
Discussion_Admin
TravisNave
Message 2 of 3 (1,601 Views)
Re: Still can't uninstall the 32 Bit Object enabler
02-27-2013 12:22 PM in reply to: vividanimations
It's looking for the original installation source.  If you deleted that, that's probably the reason.
To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
http://support.microsoft.com/mats/Program_Install_and_Uninstall
For more information on the Autodesk KB Support article concerning the clean uninstall of Autodesk products, see this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
For all other installation problems on Windows XP SP2 or below consider using the Microsoft Installer Clean Up Utility. For more information on this program, please my forum post here:
http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Installer-Clean-Up-Utility-for-Add-Re...
DarrenP
Message 3 of 3 (1,592 Views)
02-27-2013 12:30 PM in reply to: TravisNave
