Installation & Licensing
Member
Zzjuuum
Message 1 of 4 (476 Views)
Stack overflow AAAAAAAAAAAAAAAA HELP!!!!!!!
476 Views, 3 Replies
06-18-2012 01:30 AM
tryed to open file and Autocad drawing and autocad stoped working with writing stack overflow, and after that time i cant open any of autocad drawings, cant even start autocad. i tried to repair, reinstal, uninstal and instal autocad but he just dont want to start. . .  Help plz
Working on Windovs 64bit
on cpu with processor i7
8gb ram
nvidia Quadro FX 380
Problem signature:
Problem Event Name: APPCRASH
Application Name: acad.exe
Application Version: 24.1.115.0
Application Timestamp: 4c60e8b7
Fault Module Name: mscorwks.dll
Fault Module Version: 2.0.50727.4952
Fault Module Timestamp: 4bebe78c
Exception Code: c0000005
Exception Offset: 00000000005206f0
OS Version: 6.1.7600.2.0.0.256.48
Locale ID: 1033
Additional Information 1: 002e
Additional Information 2: 002ebafb76e216f1197a11e84cd5b7c8
Additional Information 3: 5d46
Additional Information 4: 5d46b19f45a9539f49b3673737d9bd34
mscorwks.dll appears to be a .NET file, so installing and reinstalling AutoCAD is not going to affect it. If you don't get any other responses, you will have to remove all versions of .NET on your PC, use a registry editor to clean up the Windows Registry afterwards, restart your PC and reinstall AutoCAD and .NET as needed.
I agree with Dean.
.NET Framework issues can be resolved using the .NET Framework Cleanup Tool. More information about this tool can be found at my discussion thread here:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Exception-Errors/td-p/3079002
Good Luck!
pendean
Message 2 of 4 (418 Views)
Re: Stack overflow AAAAAAAAAAAAAAAA HELP!!!!!!!
06-18-2012 06:04 AM in reply to: Zzjuuum
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
TravisNave
Message 3 of 4 (407 Views)
06-18-2012 07:41 AM in reply to: pendean
I agree with Dean.
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
Good Luck!
Member
Zzjuuum
Message 4 of 4 (377 Views)
06-20-2012 12:30 AM in reply to: TravisNave
First thank you!
But :smileyhappy: it doesnt work. I uninstal all framework and use taht remowal tool, and uninstal autocad complite removal. Used registry cleaner to clean all and in reg edit remowe all files i could find coneted to autocad using autodesk recomandations.... And still same . . .  stack overflow . . . .
