Hello, as my title states my SSD is in trouble with available space. I am trying to install 3DS Max onto my HDD. Where I am not having a problem setting the install path for 3DS Max itself, the problem I am getting are all the other addatives installing onto my C-drive (SSD) when I do not want it to.
For example, large files like Backburner and 3dsmax appdata files. They refuse to install onto my HDD path created.
My question is, is it possible to get those files to work elsewhere? If so, how? I really need what little SSD space I have for emergencies, at least until that unfaithful day when I upgrade to one with more space.
Thank you in advance!
Solved by DarrenP. Go to Solution.
a lot of those files being installed on C are files required by windows
DarrenP
