I had messaged the support on Twitter and was told to come here.
Basically I am getting this error:
I looked at what versions of C++ I had installed, I have a few 2005, 2008, 2010 and 2012. I didn't know which ones to remove after being linked to here:
If anyone can help me it would be greatly appreciated. I am not sure if this is of any significance but I am trying to install the student version.
Solved by TravisNave. Go to Solution.
Here is the log:
2013/12/21:18:06:13 Kieran KIERAN-PC === Setup started on KIERAN-PC by Kieran ===
2013/12/21:18:06:13 Kieran KIERAN-PC Path_Length: 151
2013/12/21:18:06:13 Kieran KIERAN-PC Current Directory C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_wi_en-US
2013/12/21:18:06:13 Kieran KIERAN-PC Launch
2013/12/21:18:06:13 Kieran KIERAN-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_wi_en... /SN 900-43940206 /PK 128F1 /student /akamai /auth authparam /sid SESSION_ID
2013/12/21:18:06:13 Kieran KIERAN-PC Current Directory C:\Users\Kieran\AppData\Local\Temp\_AIFD92.tmp
2013/12/21:18:06:56 Kieran KIERAN-PC === Setup ended ===
2013/12/21:18:06:16 Kieran KIERAN-PC === Setup started on KIERAN-PC by Kieran ===
2013/12/21:18:06:16 Kieran KIERAN-PC Path_Length: 151
2013/12/21:18:06:16 Kieran KIERAN-PC Current Directory C:\Users\Kieran\AppData\Local\Temp\_AIFD92.tmp
2013/12/21:18:06:16 Kieran KIERAN-PC Launch
2013/12/21:18:06:19 Kieran KIERAN-PC Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/SETUP...
2013/12/21:18:06:56 Kieran KIERAN-PC Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/SETUP...
2013/12/21:18:06:56 Kieran KIERAN-PC PageOpen LaunchDialog
2013/12/21:18:07:18 Kieran KIERAN-PC PageOpen LicenseDialog
2013/12/21:18:07:21 Kieran KIERAN-PC PageOpen ProductInfoDialog
2013/12/21:18:07:21 Kieran KIERAN-PC PageOpen ProductSelectionDialog2
2013/12/21:18:07:24 Kieran KIERAN-PC PageOpen FullProgressDialog
2013/12/21:18:07:24 Kieran KIERAN-PC Download Play VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/VCRED...
2013/12/21:18:07:26 Kieran KIERAN-PC Download Complete VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/VCRED...
2013/12/21:18:07:26 Kieran KIERAN-PC Installing Microsoft Visual C++ 2005 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2014\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Kieran\AppData\Local\Temp\vcredist_x64_2005.log"" "
2013/12/21:18:07:54 Kieran KIERAN-PC Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded
2013/12/21:18:07:54 Kieran KIERAN-PC Download Play DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/DIREC...
2013/12/21:18:08:36 Kieran KIERAN-PC Download Complete DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/DIREC...
2013/12/21:18:08:36 Kieran KIERAN-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2013/12/21:18:11:25 Kieran KIERAN-PC Install DirectX® Runtime Succeeded
2013/12/21:18:11:25 Kieran KIERAN-PC Download Play CM http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/CM.ta...
2013/12/21:18:11:43 Kieran KIERAN-PC Download Complete CM http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/CM.ta...
2013/12/21:18:11:43 Kieran KIERAN-PC Installing Autodesk® Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/12/21:18:12:33 Kieran KIERAN-PC Install Autodesk® Material Library 2014 Succeeded
2013/12/21:18:12:33 Kieran KIERAN-PC Download Play CMILB http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/CMILB...
2013/12/21:18:12:52 Kieran KIERAN-PC Download Complete CMILB http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/CMILB...
2013/12/21:18:12:52 Kieran KIERAN-PC Installing Autodesk® Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/12/21:18:13:12 Kieran KIERAN-PC Install Autodesk® Material Library 2014 - Base Image Library Succeeded
2013/12/21:18:13:12 Kieran KIERAN-PC Download Play CMILM http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/CMILM...
2013/12/21:18:23:54 Kieran KIERAN-PC Download Aborted CMILM http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/CMILM...
2013/12/21:18:23:54 Kieran KIERAN-PC Install Autodesk® Material Library 2014 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2013/12/21:18:24:32 Kieran KIERAN-PC Rollback Autodesk® Material Library 2014 - Base Image Library Succeeded
2013/12/21:18:25:03 Kieran KIERAN-PC Rollback Autodesk® Material Library 2014 Succeeded
2013/12/21:18:25:03 Kieran KIERAN-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2013/12/21:18:25:03 Kieran KIERAN-PC Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619
2013/12/21:18:25:04 Kieran KIERAN-PC PageOpen InstallCompleteDialog
2013/12/21:18:25:24 Kieran KIERAN-PC === Setup ended ===
2013/12/21:18:27:19 Kieran KIERAN-PC === Setup started on KIERAN-PC by Kieran ===
2013/12/21:18:27:19 Kieran KIERAN-PC Path_Length: 151
2013/12/21:18:27:19 Kieran KIERAN-PC Current Directory C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_wi_en-US
2013/12/21:18:27:19 Kieran KIERAN-PC Launch
2013/12/21:18:27:19 Kieran KIERAN-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_wi_en... /SN 900-43940206 /PK 128F1 /student /akamai /auth authparam /sid SESSION_ID
2013/12/21:18:27:19 Kieran KIERAN-PC Current Directory C:\Users\Kieran\AppData\Local\Temp\_AI4ECD.tmp
2013/12/21:18:27:26 Kieran KIERAN-PC === Setup ended ===
2013/12/21:18:27:22 Kieran KIERAN-PC === Setup started on KIERAN-PC by Kieran ===
2013/12/21:18:27:22 Kieran KIERAN-PC Path_Length: 151
2013/12/21:18:27:22 Kieran KIERAN-PC Current Directory C:\Users\Kieran\AppData\Local\Temp\_AI4ECD.tmp
2013/12/21:18:27:22 Kieran KIERAN-PC Launch
2013/12/21:18:27:25 Kieran KIERAN-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/SETUP...
2013/12/21:18:27:26 Kieran KIERAN-PC PageOpen LaunchDialog
2013/12/21:18:27:33 Kieran KIERAN-PC PageOpen LicenseDialog
2013/12/21:18:31:18 Kieran KIERAN-PC PageOpen ProductInfoDialog
2013/12/21:18:31:19 Kieran KIERAN-PC PageOpen ProductSelectionDialog2
2013/12/21:18:31:30 Kieran KIERAN-PC PageOpen FullProgressDialog
2013/12/21:18:31:30 Kieran KIERAN-PC Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/DIREC...
2013/12/21:18:31:30 Kieran KIERAN-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2013/12/21:18:33:21 Kieran KIERAN-PC Install DirectX® Runtime Succeeded
2013/12/21:18:33:21 Kieran KIERAN-PC Download Skipped CM http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/CM.ta...
2013/12/21:18:33:21 Kieran KIERAN-PC Installing Autodesk® Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/12/21:18:33:57 Kieran KIERAN-PC Install Autodesk® Material Library 2014 Succeeded
2013/12/21:18:33:57 Kieran KIERAN-PC Download Skipped CMILB http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/CMILB...
2013/12/21:18:33:57 Kieran KIERAN-PC Installing Autodesk® Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/12/21:18:34:16 Kieran KIERAN-PC Install Autodesk® Material Library 2014 - Base Image Library Succeeded
2013/12/21:18:34:16 Kieran KIERAN-PC Download Play CMILM http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/CMILM...
2013/12/21:18:37:24 Kieran KIERAN-PC Download Aborted CMILM http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/CMILM...
2013/12/21:18:37:24 Kieran KIERAN-PC Install Autodesk® Material Library 2014 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2013/12/21:18:38:37 Kieran KIERAN-PC Rollback Autodesk® Material Library 2014 - Base Image Library Succeeded
2013/12/21:18:39:48 Kieran KIERAN-PC Rollback Autodesk® Material Library 2014 Succeeded
2013/12/21:18:39:48 Kieran KIERAN-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2013/12/21:18:39:49 Kieran KIERAN-PC PageOpen InstallCompleteDialog
2013/12/21:18:41:36 Kieran KIERAN-PC === Setup ended ===
2013/12/21:18:42:58 Kieran KIERAN-PC === Setup started on KIERAN-PC by Kieran ===
2013/12/21:18:42:58 Kieran KIERAN-PC Path_Length: 151
2013/12/21:18:42:58 Kieran KIERAN-PC Current Directory C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_wi_en-US
2013/12/21:18:42:58 Kieran KIERAN-PC Launch
2013/12/21:18:42:58 Kieran KIERAN-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_wi_en... /SN 900-43940206 /PK 128F1 /student /akamai /auth authparam /sid SESSION_ID
2013/12/21:18:42:58 Kieran KIERAN-PC Current Directory C:\Users\Kieran\AppData\Local\Temp\_AIA4C9.tmp
2013/12/21:18:43:05 Kieran KIERAN-PC === Setup ended ===
2013/12/21:18:42:59 Kieran KIERAN-PC === Setup started on KIERAN-PC by Kieran ===
2013/12/21:18:42:59 Kieran KIERAN-PC Path_Length: 151
2013/12/21:18:42:59 Kieran KIERAN-PC Current Directory C:\Users\Kieran\AppData\Local\Temp\_AIA4C9.tmp
2013/12/21:18:42:59 Kieran KIERAN-PC Launch
2013/12/21:18:43:04 Kieran KIERAN-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/SETUP...
2013/12/21:18:43:04 Kieran KIERAN-PC PageOpen LaunchDialog
2013/12/21:18:43:12 Kieran KIERAN-PC PageOpen LicenseDialog
2013/12/21:18:43:22 Kieran KIERAN-PC PageOpen ProductInfoDialog
2013/12/21:18:43:22 Kieran KIERAN-PC PageOpen ProductSelectionDialog2
2013/12/21:18:43:45 Kieran KIERAN-PC PageOpen FullProgressDialog
2013/12/21:18:43:45 Kieran KIERAN-PC Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/DIREC...
2013/12/21:18:43:45 Kieran KIERAN-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2013/12/21:18:45:56 Kieran KIERAN-PC Install DirectX® Runtime Succeeded
2013/12/21:18:45:56 Kieran KIERAN-PC Download Skipped CM http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/CM.ta...
2013/12/21:18:45:56 Kieran KIERAN-PC Installing Autodesk® Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/12/21:18:46:42 Kieran KIERAN-PC Install Autodesk® Material Library 2014 Succeeded
2013/12/21:18:46:42 Kieran KIERAN-PC Download Skipped CMILB http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/CMILB...
2013/12/21:18:46:42 Kieran KIERAN-PC Installing Autodesk® Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/12/21:18:47:11 Kieran KIERAN-PC Install Autodesk® Material Library 2014 - Base Image Library Succeeded
2013/12/21:18:47:12 Kieran KIERAN-PC Download Play CMILM http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/CMILM...
2013/12/21:18:50:39 Kieran KIERAN-PC Download Aborted CMILM http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/CMILM...
2013/12/21:18:50:39 Kieran KIERAN-PC Install Autodesk® Material Library 2014 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2013/12/21:18:51:53 Kieran KIERAN-PC Rollback Autodesk® Material Library 2014 - Base Image Library Succeeded
2013/12/21:18:53:03 Kieran KIERAN-PC Rollback Autodesk® Material Library 2014 Succeeded
2013/12/21:18:53:03 Kieran KIERAN-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
The failure is on the download of the image library. I suspect this is a widespread problem with Autodesk distribution at the moment because multiple people are getting it.
Try instead to download the package from the virtual assistant.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21889745&linkID=9240617
Good Luck!
You'd probably be waiting forever if you expect this server issue to be resolved in a timely manner. Otherwise, I'd just recommend downloading it from the virtual agent. Others have had success with that.
thanks!
tried it and it worked, thanks so much for the help.. Now I have to get used to the complicated movement 😄
