Installation & Licensing
'Some products failed to install error' Need help figuring out the issue
12 REPLIES 12
Message 1 of 13
Youngy798
1772 Views, 12 Replies
I had messaged the support on Twitter and was told to come here.
Basically I am getting this error:
Here is the log I recieved:
Spoiler
2013/12/21:18:06:13 Kieran KIERAN-PC === Setup started on KIERAN-PC by Kieran ===
Spoiler
Spoiler
Spoiler
2013/12/21:18:06:13 Kieran KIERAN-PC Path_Length: 151
2013/12/21:18:06:13 Kieran KIERAN-PC Current Directory C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_wi_en-US
2013/12/21:18:06:13 Kieran KIERAN-PC Launch
2013/12/21:18:06:13 Kieran KIERAN-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_wi_en... /SN 900-43940206 /PK 128F1 /student /akamai /auth authparam /sid SESSION_ID
2013/12/21:18:06:13 Kieran KIERAN-PC Current Directory C:\Users\Kieran\AppData\Local\Temp\_AIFD92.tmp
2013/12/21:18:06:56 Kieran KIERAN-PC === Setup ended ===
2013/12/21:18:06:16 Kieran KIERAN-PC === Setup started on KIERAN-PC by Kieran ===
2013/12/21:18:06:16 Kieran KIERAN-PC Path_Length: 151
2013/12/21:18:06:16 Kieran KIERAN-PC Current Directory C:\Users\Kieran\AppData\Local\Temp\_AIFD92.tmp
2013/12/21:18:06:16 Kieran KIERAN-PC Launch
2013/12/21:18:06:19 Kieran KIERAN-PC Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/SETUP...
2013/12/21:18:06:56 Kieran KIERAN-PC Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/SETUP...
2013/12/21:18:06:56 Kieran KIERAN-PC PageOpen LaunchDialog
2013/12/21:18:07:18 Kieran KIERAN-PC PageOpen LicenseDialog
2013/12/21:18:07:21 Kieran KIERAN-PC PageOpen ProductInfoDialog
2013/12/21:18:07:21 Kieran KIERAN-PC PageOpen ProductSelectionDialog2
2013/12/21:18:07:24 Kieran KIERAN-PC PageOpen FullProgressDialog
2013/12/21:18:07:24 Kieran KIERAN-PC Download Play VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/VCRED...
2013/12/21:18:07:26 Kieran KIERAN-PC Download Complete VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/VCRED...
2013/12/21:18:07:26 Kieran KIERAN-PC Installing Microsoft Visual C++ 2005 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2014\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Kieran\AppData\Local\Temp\vcredist_x64_2005.log"" "
2013/12/21:18:07:54 Kieran KIERAN-PC Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded
2013/12/21:18:07:54 Kieran KIERAN-PC Download Play DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/DIREC...
2013/12/21:18:08:36 Kieran KIERAN-PC Download Complete DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/DIREC...
2013/12/21:18:08:36 Kieran KIERAN-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2013/12/21:18:11:25 Kieran KIERAN-PC Install DirectX® Runtime Succeeded
2013/12/21:18:11:25 Kieran KIERAN-PC Download Play CM http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/CM.ta...
2013/12/21:18:11:43 Kieran KIERAN-PC Download Complete CM http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/CM.ta...
2013/12/21:18:11:43 Kieran KIERAN-PC Installing Autodesk® Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/12/21:18:12:33 Kieran KIERAN-PC Install Autodesk® Material Library 2014 Succeeded
2013/12/21:18:12:33 Kieran KIERAN-PC Download Play CMILB http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/CMILB...
2013/12/21:18:12:52 Kieran KIERAN-PC Download Complete CMILB http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/CMILB...
2013/12/21:18:12:52 Kieran KIERAN-PC Installing Autodesk® Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/12/21:18:13:12 Kieran KIERAN-PC Install Autodesk® Material Library 2014 - Base Image Library Succeeded
2013/12/21:18:13:12 Kieran KIERAN-PC Download Play CMILM http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/CMILM...
2013/12/21:18:23:54 Kieran KIERAN-PC Download Aborted CMILM http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/CMILM...
2013/12/21:18:23:54 Kieran KIERAN-PC Install Autodesk® Material Library 2014 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2013/12/21:18:24:32 Kieran KIERAN-PC Rollback Autodesk® Material Library 2014 - Base Image Library Succeeded
2013/12/21:18:25:03 Kieran KIERAN-PC Rollback Autodesk® Material Library 2014 Succeeded
2013/12/21:18:25:03 Kieran KIERAN-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2013/12/21:18:25:03 Kieran KIERAN-PC Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619
2013/12/21:18:25:04 Kieran KIERAN-PC PageOpen InstallCompleteDialog
2013/12/21:18:25:24 Kieran KIERAN-PC === Setup ended ===
2013/12/21:18:27:19 Kieran KIERAN-PC === Setup started on KIERAN-PC by Kieran ===
2013/12/21:18:27:19 Kieran KIERAN-PC Path_Length: 151
2013/12/21:18:27:19 Kieran KIERAN-PC Current Directory C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_wi_en-US
2013/12/21:18:27:19 Kieran KIERAN-PC Launch
2013/12/21:18:27:19 Kieran KIERAN-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_wi_en... /SN 900-43940206 /PK 128F1 /student /akamai /auth authparam /sid SESSION_ID
2013/12/21:18:27:19 Kieran KIERAN-PC Current Directory C:\Users\Kieran\AppData\Local\Temp\_AI4ECD.tmp
2013/12/21:18:27:26 Kieran KIERAN-PC === Setup ended ===
2013/12/21:18:27:22 Kieran KIERAN-PC === Setup started on KIERAN-PC by Kieran ===
2013/12/21:18:27:22 Kieran KIERAN-PC Path_Length: 151
2013/12/21:18:27:22 Kieran KIERAN-PC Current Directory C:\Users\Kieran\AppData\Local\Temp\_AI4ECD.tmp
2013/12/21:18:27:22 Kieran KIERAN-PC Launch
2013/12/21:18:27:25 Kieran KIERAN-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/SETUP...
2013/12/21:18:27:26 Kieran KIERAN-PC PageOpen LaunchDialog
2013/12/21:18:27:33 Kieran KIERAN-PC PageOpen LicenseDialog
2013/12/21:18:31:18 Kieran KIERAN-PC PageOpen ProductInfoDialog
2013/12/21:18:31:19 Kieran KIERAN-PC PageOpen ProductSelectionDialog2
2013/12/21:18:31:30 Kieran KIERAN-PC PageOpen FullProgressDialog
2013/12/21:18:31:30 Kieran KIERAN-PC Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/DIREC...
2013/12/21:18:31:30 Kieran KIERAN-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2013/12/21:18:33:21 Kieran KIERAN-PC Install DirectX® Runtime Succeeded
2013/12/21:18:33:21 Kieran KIERAN-PC Download Skipped CM http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/CM.ta...
2013/12/21:18:33:21 Kieran KIERAN-PC Installing Autodesk® Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/12/21:18:33:57 Kieran KIERAN-PC Install Autodesk® Material Library 2014 Succeeded
2013/12/21:18:33:57 Kieran KIERAN-PC Download Skipped CMILB http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/CMILB...
2013/12/21:18:33:57 Kieran KIERAN-PC Installing Autodesk® Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/12/21:18:34:16 Kieran KIERAN-PC Install Autodesk® Material Library 2014 - Base Image Library Succeeded
2013/12/21:18:34:16 Kieran KIERAN-PC Download Play CMILM http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/CMILM...
2013/12/21:18:37:24 Kieran KIERAN-PC Download Aborted CMILM http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/CMILM...
2013/12/21:18:37:24 Kieran KIERAN-PC Install Autodesk® Material Library 2014 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2013/12/21:18:38:37 Kieran KIERAN-PC Rollback Autodesk® Material Library 2014 - Base Image Library Succeeded
2013/12/21:18:39:48 Kieran KIERAN-PC Rollback Autodesk® Material Library 2014 Succeeded
2013/12/21:18:39:48 Kieran KIERAN-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2013/12/21:18:39:49 Kieran KIERAN-PC PageOpen InstallCompleteDialog
2013/12/21:18:41:36 Kieran KIERAN-PC === Setup ended ===
2013/12/21:18:42:58 Kieran KIERAN-PC === Setup started on KIERAN-PC by Kieran ===
2013/12/21:18:42:58 Kieran KIERAN-PC Path_Length: 151
2013/12/21:18:42:58 Kieran KIERAN-PC Current Directory C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_wi_en-US
2013/12/21:18:42:58 Kieran KIERAN-PC Launch
2013/12/21:18:42:58 Kieran KIERAN-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_wi_en... /SN 900-43940206 /PK 128F1 /student /akamai /auth authparam /sid SESSION_ID
2013/12/21:18:42:58 Kieran KIERAN-PC Current Directory C:\Users\Kieran\AppData\Local\Temp\_AIA4C9.tmp
2013/12/21:18:43:05 Kieran KIERAN-PC === Setup ended ===
2013/12/21:18:42:59 Kieran KIERAN-PC === Setup started on KIERAN-PC by Kieran ===
2013/12/21:18:42:59 Kieran KIERAN-PC Path_Length: 151
2013/12/21:18:42:59 Kieran KIERAN-PC Current Directory C:\Users\Kieran\AppData\Local\Temp\_AIA4C9.tmp
2013/12/21:18:42:59 Kieran KIERAN-PC Launch
2013/12/21:18:43:04 Kieran KIERAN-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/SETUP...
2013/12/21:18:43:04 Kieran KIERAN-PC PageOpen LaunchDialog
2013/12/21:18:43:12 Kieran KIERAN-PC PageOpen LicenseDialog
2013/12/21:18:43:22 Kieran KIERAN-PC PageOpen ProductInfoDialog
2013/12/21:18:43:22 Kieran KIERAN-PC PageOpen ProductSelectionDialog2
2013/12/21:18:43:45 Kieran KIERAN-PC PageOpen FullProgressDialog
2013/12/21:18:43:45 Kieran KIERAN-PC Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/DIREC...
2013/12/21:18:43:45 Kieran KIERAN-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2013/12/21:18:45:56 Kieran KIERAN-PC Install DirectX® Runtime Succeeded
2013/12/21:18:45:56 Kieran KIERAN-PC Download Skipped CM http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/CM.ta...
2013/12/21:18:45:56 Kieran KIERAN-PC Installing Autodesk® Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/12/21:18:46:42 Kieran KIERAN-PC Install Autodesk® Material Library 2014 Succeeded
2013/12/21:18:46:42 Kieran KIERAN-PC Download Skipped CMILB http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/CMILB...
2013/12/21:18:46:42 Kieran KIERAN-PC Installing Autodesk® Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/12/21:18:47:11 Kieran KIERAN-PC Install Autodesk® Material Library 2014 - Base Image Library Succeeded
2013/12/21:18:47:12 Kieran KIERAN-PC Download Play CMILM http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/CMILM...
2013/12/21:18:50:39 Kieran KIERAN-PC Download Aborted CMILM http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/CMILM...
2013/12/21:18:50:39 Kieran KIERAN-PC Install Autodesk® Material Library 2014 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2013/12/21:18:51:53 Kieran KIERAN-PC Rollback Autodesk® Material Library 2014 - Base Image Library Succeeded
2013/12/21:18:53:03 Kieran KIERAN-PC Rollback Autodesk® Material Library 2014 Succeeded
2013/12/21:18:53:03 Kieran KIERAN-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
I looked at what versions of C++ I had installed, I have a few 2005, 2008, 2010 and 2012. I didn't know which ones to remove after being linked to here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
If anyone can help me it would be greatly appreciated. I am not sure if this is of any significance but I am trying to install the student version.
12 REPLIES 12
Message 2 of 13
TravisNave
in reply to: Youngy798
This has been answered by me in your other post here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21889745&linkID=9240617
Thanks.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 3 of 13
SuperBKDK
in reply to: TravisNave
That link you put up doesn't work, I have the same exact problem.
Message 4 of 13
jessica.t
in reply to: SuperBKDK
Hi @SuperBKDK,
Try this solution posted in @TravisNave's signature. Let us know how it goes. Thanks!
Jessica Thrasher
Message 5 of 13
SuperBKDK
in reply to: jessica.t
That did it! Thank you. I had to use the 30 day trial, but I am a high
school student on summer vacation. If I am not using the product to make
money, how do I get the student registration?
Message 6 of 13
jessica.t
Hi @SuperBKDK,
So glad to hear that solution worked for you! To register as a student receive free software, just sign up at our Education Community. If you have any other questions just let us know. Thanks!
Jessica Thrasher
Message 7 of 13
SuperBKDK
Hi Jessica,
How do I find the serial or registration number? I sign into my autodesk
account, but it doesn't say anything about 3d studio MAX. I want to make
games and this is the best tool to work with Unity. I also already took a
design class in High School using Adobe Photoshop, but I want to make games
after I graduate.
Thank you,
Blake
Message 8 of 13
jessica.t
Hi @SuperBKDK,
When you registered for the Education Community and you selected the product in which you wanted to download, the serial number and product key should have been presented to you. Were you able to choose a product to download?
Please see this Education Community Serial Number FAQ for further details. If you have any other questions please let us know. Thank you!
Jessica Thrasher
Message 9 of 13
SuperBKDK
Thank you SO MUCH!!!! I was able to register it now I can start making
characters for my game!
Message 10 of 13
jessica.t
You're welcome! Enjoy! Smiley Happy
Jessica Thrasher
Message 11 of 13
SuperBKDK
Jessica,
My computer crashed and I rebuilt it but when I tried to install 3D Studio, it won't extract. I tried both the download manager and the other version. It doesn't extract all the way and it stops. I let it run overnight and it still stops. I tried deleting all the files it doesn't install and tried to use the material installer like it said on the community forum.
How can I get this to work?
Thank you,
Blake Kelly
Message 12 of 13
Mark.Lancaster
@SuperBKDK
In the future use @<their account id> method to catch someone's attention.   This posting is over 2 years and Jessica or the others may not even see your reply.
Did you go to the Autodesk Virtual Agent and follow the download links to your product.  Download all of the parts first and then go to your download location.  Extract (double click) part 1 and in a few seconds the extraction will start.   It will then prompt you to extract to C:\Autodesk and once the extraction is finished the installation will start.
Mark Lancaster
Message 13 of 13
SuperBKDK
in reply to: Mark.Lancaster
I tried 2015 install again, and 2016, and 2017, and I can't get any to work 😞 It tells me in the %TEMP% folder, in the log file, that the files are not verified. Or it will tell me a cabinet file is corrupted, either materials cab file, or base_T~1.cab file is corrupt and cannot be used. I tried downloading using the virtual assistant, and with the web installer. I checked that the file sizes are good when I downloaded both of them. I tried installing in safe mode with network. I tried uninstalling, and clearing out autodesk.
The only thing I have not tried is installing on a brand new machine and I can't afford to do that. So what do I do now?
Tags (1)
Administrator Productivity
