Installation & Licensing
Some products failed to install (already deleted Microsoft Visual c++)
2 REPLIES 2
273 Views, 2 Replies
Hi Guys,
So I've tried downloading AutoCad numerous times. I kept getting the error message "Installation complete, some products failed to install". I learned that microsoft visual c++ 2008 etc file can be the cause of this. I deleted the file and another named microsoft visual etc but I still get the same error message and the log is the same as before. Here is the log i Get:
2014/10/6:20:56:35 xx USER-PC === Setup started on USER-PC by xx ===
2014/10/6:20:56:35 xxUSER-PC Launch
2014/10/6:20:56:35 xx USER-PC CommandLine /url ://trial.autodesk.com/SWDLDDLM/2013/ACD/WI/AutoCAD_2013_English_Win_32_64bit_wi_en-US_Setup1.exe" /SN 900-50240662 /PK 001E1 /student  /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/10/6:20:57:35 xx USER-PC === Setup ended ===
2014/10/6:20:56:37  xxUSER-PC === Setup started on USER-PC by xx===
2014/10/6:20:56:37 xx USER-PC Launch
2014/10/6:20:57:35 xx USER-PC Download Skipped SETUP_CONFIG http://trial.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SETUP_x64.tar....
2014/10/6:20:57:35 xx USER-PC PageOpen LaunchDialog
2014/10/6:20:58:55 xx USER-PC PageOpen LicenseDialog
2014/10/6:20:58:55 xx USER-PC PageOpen ProductInfoDialog
2014/10/6:20:58:55 xx USER-PC PageOpen ProductSelectionDialog2
2014/10/6:21:00:21 xx USER-PC PageOpen FullProgressDialog
2014/10/6:21:00:22 xx USER-PC Download Skipped VCREDIST2008SP1X86 http://trial.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/VCREDIST2008SP...
2014/10/6:21:00:22 xxUSER-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Autodesk\WI\AutoCAD 2013\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2014/10/6:21:00:39 xx USER-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
Any Help Would be greatly Appreciated, thanks a lot!
2 REPLIES 2
aaronhai
Hi Luke,
Welcome to Autodesk Community. Please remove and re-install Microsoft Visual C++ runtime and see if that works for you.
Thank you.
Aaron Hai
sreichenbach
I has a similar problem, and someone told me that I have to install 3rd party product manually... but it doesn't work anyway.
I find a way here :
http://forums.autodesk.com/t5/installation-licensing/install-material-library-2015-failed-installati...
maybe try the CM component install test ?
SR
Administrator Productivity
