Installation & Licensing
Member
0 Kudos
Post 1 of 32
Some Products Fail to Install Result=1619 Max 2014
6292 Views, 31 Replies
08-15-2013 11:01 AM
i'm trying to install max 2014 i already have installed 2013 and 2014 is being installed under the same folder.
running on windows 7 64 bits.
From this Post: Some Products Fail to Install, Result 1603
I also uninstall microsoft visual C++ 210 x64 and x86 before install Max but i still get the error, i didnt figure how to uninstall directX or what to do about it.
2013/8/15:18:31:16 Bruno BRUNO-LAPTOP Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2013/8/15:18:31:16 Bruno BRUNO-LAPTOP Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2013/8/15:18:31:16 Bruno BRUNO-LAPTOP Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted,
3D Artist / Graphic Designer
Bruno Silva
ok i figure what was causing the error it was because i didn«t had permission on the autodesk folder.
I just took ownership and took full control and that's it. it's installed.
903 Kudos
Post 2 of 32
Re: Some Products Fail to Install Result=1619 Max 2014
08-15-2013 11:16 AM in reply to: brunofsfx
It's failing for a completely different reason, but you will need the larger install log from the %TEMP% folder to help identify it.
Member
0 Kudos
Post 3 of 32
08-15-2013 11:20 AM in reply to: TravisNave
you mean this?
Bruno Silva
903 Kudos
Post 4 of 32
08-15-2013 11:57 AM in reply to: brunofsfx
No I mean the bigger one in your %TEMP% folder.
Member
0 Kudos
Post 5 of 32
08-15-2013 11:59 AM in reply to: brunofsfx
Bruno Silva
903 Kudos
Post 6 of 32
08-15-2013 01:23 PM in reply to: brunofsfx
Give yourself full control of this folder and its contents.  The problem seems to be failing here:
C:\ProgramData\Autodesk\Synergy\
MSI (s) (F8:34) [18:26:38:254]: Executing op: FolderCreate(Folder=C:\ProgramData\Autodesk\Synergy\,Foreign=0,,)
MSI (s) (F8:34) [18:26:38:257]: Note: 1: 1326 2: 5 3: C:\ProgramData\Autodesk\Synergy\
MSI (s) (F8:34) [18:26:38:257]: Note: 1: 2205 2:  3: Error
MSI (s) (F8:34) [18:26:38:257]: Note: 1: 2228 2:  3: Error 4: SELECT `Message` FROM `Error` WHERE `Error` = 1326
MSI (s) (F8:34) [18:28:13:104]: Note: 1: 2205 2:  3: Error
MSI (s) (F8:34) [18:28:13:104]: Note: 1: 2228 2:  3: Error 4: SELECT `Message` FROM `Error` WHERE `Error` = 1709
MSI (s) (F8:34) [18:28:13:104]: Product: Autodesk 3ds Max 2014 -- Error 1326. Error getting file security: C:\ProgramData\Autodesk\Synergy\ GetLastError: 5
Member
0 Kudos
Post 7 of 32
08-15-2013 02:00 PM in reply to: TravisNave
Now i got this.
and after giving permission and pressing retry  autodesk installer get's stuck at 8 remaining of 15
Bruno Silva
Member
0 Kudos
Post 8 of 32
08-16-2013 02:29 AM in reply to: brunofsfx
Bruno Silva
0 Kudos
Post 9 of 32
10-17-2013 10:35 AM in reply to: brunofsfx
Hello.
I have a similar problem. I have read through this discussion, but I kind of got lost. Can you help me as well? I receive the same error nr 1619 when trying to install max.
903 Kudos
Post 10 of 32
10-17-2013 10:40 AM in reply to: ileanagreere
Actually post the logfile, it will be more helpful.
Recommendations to follow during installation:
1.  Install with local administrator rights
2.  Disable UAC
3.  Turn off Anti-virus
4.  Do not install service packs during the installation
Good Luck.
