Installation & Licensing
Some Products Fail to Install, Result 1603/1619
3 REPLIES 3
trevormcneill
2762 Views, 3 Replies
2013/9/14:19:31:21	TrevorMcNeill	TREVOR	=== Setup started on TREVOR by TrevorMcNeill ===
2013/9/14:19:31:21	TrevorMcNeill	TREVOR	Path_Length: 151
2013/9/14:19:31:21	TrevorMcNeill	TREVOR	Current Directory C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_wi_en-US
2013/9/14:19:31:21	TrevorMcNeill	TREVOR	Launch
2013/9/14:19:31:21	TrevorMcNeill	TREVOR	CommandLine	/url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/Autodesk_3ds_Max_2014_EFGJKS_Win_6... /SN 900-41328624 /PK 128F1 /student /skipEULA /akamai /auth  /sid
2013/9/14:19:31:21	TrevorMcNeill	TREVOR	Current Directory C:\Users\TREVOR~1\AppData\Local\Temp\_AI7215.tmp
2013/9/14:19:31:25	TrevorMcNeill	TREVOR	=== Setup ended ===
2013/9/14:19:31:22	TrevorMcNeill	TREVOR	=== Setup started on TREVOR by TrevorMcNeill ===
2013/9/14:19:31:22	TrevorMcNeill	TREVOR	Path_Length: 151
2013/9/14:19:31:22	TrevorMcNeill	TREVOR	Current Directory C:\Users\TREVOR~1\AppData\Local\Temp\_AI7215.tmp
2013/9/14:19:31:22	TrevorMcNeill	TREVOR	Launch
2013/9/14:19:31:23	TrevorMcNeill	TREVOR	Download	Skipped	SETUP_CONFIG	http://studentsdownload.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024...
2013/9/14:19:31:25	TrevorMcNeill	TREVOR	PageOpen	LaunchDialog
2013/9/14:19:31:28	TrevorMcNeill	TREVOR	PageOpen	LicenseDialog
2013/9/14:19:31:28	TrevorMcNeill	TREVOR	PageOpen	ProductInfoDialog
2013/9/14:19:31:28	TrevorMcNeill	TREVOR	PageOpen	ProductSelectionDialog2
2013/9/14:19:31:31	TrevorMcNeill	TREVOR	PageOpen	FullProgressDialog
2013/9/14:19:31:32	TrevorMcNeill	TREVOR	Download	Play	VCREDIST2005SP1ATLX86	http://studentsdownload.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024...
2013/9/14:19:31:35	TrevorMcNeill	TREVOR	Download	Complete	VCREDIST2005SP1ATLX86	http://studentsdownload.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024...
2013/9/14:19:31:35	TrevorMcNeill	TREVOR	Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2014\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\TREVOR~1\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/9/14:19:31:43	TrevorMcNeill	TREVOR	Install	Microsoft Visual C++ 2005 Redistributable (x86)	Succeeded
2013/9/14:19:31:43	TrevorMcNeill	TREVOR	Download	Skipped	VCREDIST2005SP1ATLX64	http://studentsdownload.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024...
2013/9/14:19:31:43	TrevorMcNeill	TREVOR	Installing Microsoft Visual C++ 2005 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2014\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\TREVOR~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2013/9/14:19:31:50	TrevorMcNeill	TREVOR	Install	Microsoft Visual C++ 2005 Redistributable (x64)	Failed	Installation aborted, Result=1603
2013/9/14:19:31:50	TrevorMcNeill	TREVOR	Rollback	Microsoft Visual C++ 2005 Redistributable (x86)	Failed	Installation aborted, Result=1619
 i have tried so many things suggested on the fourms it has finally installed the 86 version of microsoft c++ but then fails on the 64 version if anyone can help it would be much appreciated
BTW a couple of things i have tried have been uninstalling the microsoft c++, deleting temp files, and editing the setup.ini to skip the check for it but it still checks for some reason
3 REPLIES 3
avto
in reply to: trevormcneill
Hello and welcome to the forums.
To be sure that you have the complete content of 3ds Max 2014 installer locally on your system, please download your product installer using “Browser Download” method or via Autodesk virtual agent.
1.Go to http://www.autodesk.com
2.At the bottom of the page, beneath Help and Support, click Customer Service.
3.Click the Ask button.
4.In the Virtual Agent window, click Downloading and Installation.
5.Click Software Download links.
6.Click "I need to redownload my product."
7.Click on 3ds Max Products.
8.Select Autodesk 3ds Max 2014.
Then uninstall all installed Visual C++ redistributables from your system and try installing your product as follows:
1.Logon as an Administrator.
2.Empty your TEMP folder.  To open the TEMP folder, type %TEMP% in the address bar of Windows Explorer and hit Enter.
Note:  If your product installation fails and you decide to open a Support Request with Autodesk Product Support, we would need to review install logs created in your TEMP folder during this product installation attempt.
3.Disable your Antivirus software.
4.Disable UAC.
http://windows.microsoft.com/en-ca/windows7/turn-user-account-control-on-or-off
5.start installing 3ds Max 2014 from newly downloaded installer.
Hope this helps.
Avto Chachava
TravisNave
If it still checks, then you have not correctly modified the file.  Try commenting out the entire PREREQUISTE line altogether then.
Autodesk Forums:
trevormcneill
in reply to: TravisNave
thank you both for your help deleting the whole prerequisite line fixed it i guess taking out just the microsoft c++ line from it wasn't enough.
Administrator Productivity
