Installation & Licensing
Some Products Fail to install problem
17 REPLIES 17
Message 1 of 18
Arnald23
2017 Views, 17 Replies
Hello my name is Arnald23 and I have a problem with the download for Maya 2014 on my laptop. Once I go to install now it and afterclicking install after 3 mins it gives me an error saying Some Products Fail to install and everything didn't install. I reied the other download that the website provides but nothing happens, it still gives me the same problem. I downloaded maya on other computer before with no problem but my laptop is giving mr problems and I don't know what to do. If anyone can help me I would appriciated.
I have a Windows 7 Home 64bit if you are wondering,
Tags (1)
17 REPLIES 17
Message 2 of 18
TravisNave
in reply to: Arnald23
Include the installation log file from your summary screen or your %TEMP% folder.  It will help determine the failure.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 3 of 18
Arnald23
in reply to: TravisNave
OK I will update it with the Maya2014Setup they created with %temp%.
Message 4 of 18
Arnald23
2013/6/2:17:37:31 Badu BADU === Setup started on BADU by Badu ===
2013/6/2:17:37:31 Badu BADU Path_Length: 151
2013/6/2:17:37:31 Badu BADU Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2013/6/2:17:37:31 Badu BADU Launch
2013/6/2:17:37:31 Badu BADU CommandLine /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/MAYA/WI/Autodesk_Maya_2014_wi_en-US_Setup.exe" /SN 900-32970794 /PK 657F1 /student /skipEULA /akamai /auth /sid
2013/6/2:17:37:31 Badu BADU Current Directory C:\Users\Badu\AppData\Local\Temp\_AIF31A.tmp
2013/6/2:17:37:38 Badu BADU === Setup ended ===
2013/6/2:17:37:34 Badu BADU === Setup started on BADU by Badu ===
2013/6/2:17:37:34 Badu BADU Path_Length: 151
2013/6/2:17:37:34 Badu BADU Current Directory C:\Users\Badu\AppData\Local\Temp\_AIF31A.tmp
2013/6/2:17:37:34 Badu BADU Launch
2013/6/2:17:37:35 Badu BADU Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/S...
2013/6/2:17:37:38 Badu BADU PageOpen LaunchDialog
2013/6/2:17:37:48 Badu BADU PageOpen LicenseDialog
2013/6/2:17:37:48 Badu BADU PageOpen ProductInfoDialog
2013/6/2:17:37:48 Badu BADU PageOpen ProductSelectionDialog2
2013/6/2:17:37:53 Badu BADU PageOpen FullProgressDialog
2013/6/2:17:37:53 Badu BADU Download Skipped VCREDIST2005SP1ATLX86 http://studentsdownload.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/V...
2013/6/2:17:37:53 Badu BADU Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\WI\Autodesk Maya 2014\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Badu\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/6/2:17:38:25 Badu BADU Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2013/6/2:17:38:28 Badu BADU PageOpen InstallCompleteDialog
2013/6/2:17:44:28 Badu BADU === Setup ended ===
2013/6/2:18:56:36 Badu BADU === Setup started on BADU by Badu ===
2013/6/2:18:56:36 Badu BADU Path_Length: 151
2013/6/2:18:56:36 Badu BADU Current Directory C:\Autodesk\Autodesk_Maya_2014_dlm
2013/6/2:18:56:36 Badu BADU Launch
2013/6/2:18:56:36 Badu BADU CommandLine
2013/6/2:18:56:36 Badu BADU Current Directory C:\Users\Badu\AppData\Local\Temp\_AI58FF.tmp
2013/6/2:18:57:10 Badu BADU === Setup ended ===
2013/6/2:18:56:49 Badu BADU === Setup started on BADU by Badu ===
2013/6/2:18:56:49 Badu BADU Path_Length: 151
2013/6/2:18:56:49 Badu BADU Current Directory C:\Users\Badu\AppData\Local\Temp\_AI58FF.tmp
2013/6/2:18:56:49 Badu BADU Launch
2013/6/2:18:57:05 Badu BADU PageOpen LaunchDialog
2013/6/2:18:57:42 Badu BADU PageOpen LicenseDialog
2013/6/2:18:57:46 Badu BADU PageOpen ProductInfoDialog
2013/6/2:18:58:27 Badu BADU PageOpen ProductSelectionDialog2
2013/6/2:18:58:31 Badu BADU PageOpen FullProgressDialog
2013/6/2:18:58:33 Badu BADU Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Badu\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/6/2:18:59:30 Badu BADU Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2013/6/2:18:59:49 Badu BADU PageOpen InstallCompleteDialog
2013/6/2:19:04:29 Badu BADU === Setup ended ===
2013/6/3:18:21:39 Badu BADU === Setup started on BADU by Badu ===
2013/6/3:18:21:39 Badu BADU Path_Length: 151
2013/6/3:18:21:39 Badu BADU Current Directory C:\Autodesk\Autodesk_Maya_2014_dlm
2013/6/3:18:21:39 Badu BADU Launch
2013/6/3:18:21:39 Badu BADU CommandLine
2013/6/3:18:21:39 Badu BADU Current Directory C:\Users\Badu\AppData\Local\Temp\_AIB5C8.tmp
2013/6/3:18:22:15 Badu BADU === Setup ended ===
2013/6/3:18:21:56 Badu BADU === Setup started on BADU by Badu ===
2013/6/3:18:21:56 Badu BADU Path_Length: 151
2013/6/3:18:21:56 Badu BADU Current Directory C:\Users\Badu\AppData\Local\Temp\_AIB5C8.tmp
2013/6/3:18:21:56 Badu BADU Launch
2013/6/3:18:22:15 Badu BADU PageOpen LaunchDialog
2013/6/3:18:22:34 Badu BADU PageOpen LicenseDialog
2013/6/3:18:22:39 Badu BADU PageOpen ProductInfoDialog
2013/6/3:18:23:59 Badu BADU PageOpen ProductSelectionDialog2
2013/6/3:18:24:04 Badu BADU PageOpen FullProgressDialog
2013/6/3:18:24:05 Badu BADU Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Badu\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/6/3:18:24:45 Badu BADU Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2013/6/3:18:24:57 Badu BADU PageOpen InstallCompleteDialog
2013/6/3:18:25:56 Badu BADU === Setup ended ===
2013/6/3:18:46:19 Badu BADU === Setup started on BADU by Badu ===
2013/6/3:18:46:19 Badu BADU Path_Length: 151
2013/6/3:18:46:19 Badu BADU Current Directory C:\Autodesk\Autodesk_Maya_2014_dlm
2013/6/3:18:46:19 Badu BADU Launch
2013/6/3:18:46:19 Badu BADU CommandLine
2013/6/3:18:46:19 Badu BADU Current Directory C:\Users\Badu\AppData\Local\Temp\_AI4CE9.tmp
2013/6/3:18:47:00 Badu BADU === Setup ended ===
2013/6/3:18:46:38 Badu BADU === Setup started on BADU by Badu ===
2013/6/3:18:46:38 Badu BADU Path_Length: 151
2013/6/3:18:46:38 Badu BADU Current Directory C:\Users\Badu\AppData\Local\Temp\_AI4CE9.tmp
2013/6/3:18:46:38 Badu BADU Launch
2013/6/3:18:46:56 Badu BADU PageOpen LaunchDialog
2013/6/3:19:00:46 Badu BADU PageOpen LicenseDialog
2013/6/3:19:00:50 Badu BADU PageOpen ProductInfoDialog
2013/6/3:19:01:21 Badu BADU PageOpen ProductSelectionDialog2
2013/6/3:19:01:24 Badu BADU PageOpen FullProgressDialog
2013/6/3:19:01:24 Badu BADU Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\Autodesk_Maya_2014_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Badu\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/6/3:19:02:31 Badu BADU Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2013/6/3:19:02:45 Badu BADU PageOpen InstallCompleteDialog
2013/6/3:19:04:36 Badu BADU === Setup ended ===
2013/6/3:19:18:25 Badu BADU === Setup started on BADU by Badu ===
2013/6/3:19:18:25 Badu BADU Path_Length: 151
2013/6/3:19:18:25 Badu BADU Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2013/6/3:19:18:25 Badu BADU Launch
2013/6/3:19:18:25 Badu BADU CommandLine /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/MAYA/WI/Autodesk_Maya_2014_wi_en-US_Setup.exe" /SN 900-32970794 /PK 657F1 /student /skipEULA /akamai /auth /sid
2013/6/3:19:18:25 Badu BADU Current Directory C:\Users\Badu\AppData\Local\Temp\_AIB241.tmp
2013/6/3:19:18:39 Badu BADU === Setup ended ===
2013/6/3:19:18:34 Badu BADU === Setup started on BADU by Badu ===
2013/6/3:19:18:34 Badu BADU Path_Length: 151
2013/6/3:19:18:34 Badu BADU Current Directory C:\Users\Badu\AppData\Local\Temp\_AIB241.tmp
2013/6/3:19:18:34 Badu BADU Launch
2013/6/3:19:18:36 Badu BADU Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/S...
2013/6/3:19:18:39 Badu BADU PageOpen LaunchDialog
2013/6/3:19:22:16 Badu BADU PageOpen LicenseDialog
2013/6/3:19:22:16 Badu BADU PageOpen ProductInfoDialog
2013/6/3:19:22:16 Badu BADU PageOpen ProductSelectionDialog2
2013/6/3:19:24:50 Badu BADU PageOpen FullProgressDialog
2013/6/3:19:24:50 Badu BADU Download Skipped VCREDIST2005SP1ATLX86 http://studentsdownload.autodesk.com/SWDLDNET3/2014/MAYA/WI/{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/V...
2013/6/3:19:24:50 Badu BADU Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\WI\Autodesk Maya 2014\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Badu\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/6/3:19:25:22 Badu BADU Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2013/6/3:19:25:27 Badu BADU PageOpen InstallCompleteDialog
2013/6/3:19:32:34 Badu BADU === Setup ended ===
Message 5 of 18
TravisNave
You can try to install this update manually from Microsoft.  Or you can edit your setup.ini to ignore it.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
http://forums.autodesk.com/t5/Installation-Licensing/Install-NET-Framework-Language-Pack-Failed-Inst...
Autodesk Forums:
Message 6 of 18
Arnald23
I tried to install the Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) from the microsoft sitw and when it almost finish it gives me an error saying error 1935 occur and I don't know what to do 😞
Message 7 of 18
Arnald23
Ok now im angry with this! I installed maya 2014 on 5 computer in the pass and I can't do it with this one! I tried everything I can and I need someone to explain to me STEP by STEP how to install this thing!
I tried the method where for the 1603 error where you uninstal the mricosoft program that is causing the error, for me it was Microsoft visual C++ 2005 SP1 Redistributable Pack x86, after that I tried to install it will all the methods and nothing happened. Ok so I was thinking of reinstalling that program in to see if it will change anything and now I can't everytime I tried it gives me error 1935! I can't do anything I can't reinstall this, I cant install maya 2014 im stuck I NEED HELP!
Message 8 of 18
TravisNave
The problem is not with your Autodesk software, but the Microsoft prerequisite.  It simply doesn't want to install on your machine.  What you might try is modifying your setup.ini to ignore (or even delete) the check for this prerequisite.
Autodesk Forums:
Message 9 of 18
Arnald23
OK im looking at the info on thus lick you gave mne: http://forums.autodesk.com/t5/Installation-Licensing/Install-NET-Framework-Language-Pack-Failed-Inst... just mnakeing sure.
I already have Microsoft.NET Framework 4 Clint Profile on my computer does that mean I have to download it again due to the steps ot uninstall that and download the one that is in the link in other workds this one: http://www.microsoft.com/en-us/download/details.aspx?id=3324
If I do have to uninstall it and download this one how will I do that since they discontinue the english version and this is my only language? I also tried to look for the Setup.ini file on my computer since I already have that version on and there is nothing.  so many question and no answer -_-
Message 10 of 18
TravisNave
No, I mean modify the setup.ini in your Autodesk installer to remove or ignore the check for the prerequisite installed program.  That way you can at least get it installed and possibly running.
Autodesk Forums:
Message 11 of 18
Arnald23
But how do I find the setup.ini? everytime I look for it in my computer and there is nothing, i tried while installing maya and there is nothing. I downloaded the language pack in japaness for framework and I still can't find the setup.ini.
Message 12 of 18
TravisNave
It's in the root of your Autodesk installation media along with setup.exe.
Autodesk Forums:
Message 13 of 18
Arnald23
Well I look I did the following, I when to the C:/ Autodesk/ Autodesk_Maya_2014_wi_en-US and then in there I founf the setup text file. So then I did the following steps.
Step 2:  Locate the file in the root source folder named Setup.ini and make a backup of this file.  Open the file in Notepad for editing.
Step 3:  Perform a search to find the [DOTNET4LANG] located in this file.  Later versions may have newer language file prerequisites, such as [DOTNET45LANG], etc.
Step 4:  Add the following line to the prerequisite grouping under the existing EXE_ settings:
IGNORE_FAILURE=YES
I located the folder and made a backup copy of the text file name setup. I look inside it and I can't find the DOTNET4LANG anywhere or the DOTNET45LANG. This is the whole thing I found inside that setup text file.
Spoiler
[SETUP]
SETUP_CODE={44FFD99B-4877-4732-AA33-2FD3D7B622D2}
SETUP_ICON= SetupRes\maya.ico
TITLE=\Autodesk Maya 2014
LOG=%tmp%\Maya2014Setup.log
EVALMSI=SetupRes\eval.msi
PRIMARY_MSI=x64\Maya\Maya2014.msi
PLATFORM=x64
SYSUPDATE=MSI
RESOURCE_PATH=%lang%\SetupRes
LPMODE=NO_UI
AVAILABLELANGUAGES=en-US
DEFAULTMEDIALANGUAGE=en-US
DOCUMENT_LINK=http://www.autodesk.com/installation-help-2014-%setupuilang%?contextId=MAYAINSTALLTOP
DOCUMENT_FALLBACK_LINK=Docs\contexthelp\MAYAINSTALLTOP.htm
SUPPORT_LINK=http://www.autodesk.com/maya-readme-2014-%setupuilang%
SUPPORT_FALLBACK_LINK=Docs\contexthelp\ECSINSTALL404.htm
SYSTEMREQUIRE_LINK=http://www.autodesk.com/maya-systemreq-2014-%setupuilang%
SYSTEMREQUIRE_FALLBACK_LINK=Docs\contexthelp\ECSINSTALL404.htm
ERROR_PAGE=Docs\contexthelp\ECSINSTALL404.htm
#==================== Platform Requirement
OSMAJVER=5
OSMINVER=1
SPMAJVER=2
#==================== Graphics Card Check
#OGS_XML_FILE=Setup\OgsTest.xml
#==================== Install Execute & UI Sequence
#Maya Sequences
EXE_SEQUENCE=Maya;MentalRayPlugIn;MatchMover;Composite;Backburner;DirectConnect;NLM
INSTALL_SEQUENCE=Maya;MentalRayPlugIn;MatchMover;Composite;Backburner;DirectConnect;NLM
UI_SEQUENCE=LaunchDlg;BeginDeploymentDlg;LicenseDlg;ProductInfoDlg;ProductSelectionDlg2;Maya;NLM;FullProgressDlg;InstallCompleteDlg;DeploymentCompleteDlg;DeploymentFailedDlg
#==================== UI
UI_MODE=
#==================== AdLM ProdKey Info
ADLM_CONFIG_FILE=Setup\MayaConfig.pit
ADLM_PIT_DLL=Setup\adlmPIT.dll
ADLM_VERSION=2014.0.0.F
ADLM_TRIAL_DAYS=30
#==================== Install Info
INSTALL_PATH=%ProgramFiles%\Autodesk
CREATE_DESKTOP_SHORTCUT=YES
#==================== Deployment Info
DEPLOYMENT_NAME=
CLIENT_LOGGING=YES
EXTRA_FILES=Maya;*.exe:Setup:CER:eula:NLSDL:SetupRes:en-US:ja-JP:zh-CN:3rdParty:x64\Tools
#==================== Global MSI Properties
PATH_LENGTH=151
URL={DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/SETUP_x64.tar.lzma2
DOWNLOAD_UNCOMPSIZE=57196777
DOWNLOAD_COMPSIZE=20448296
RELEASE_GUID={DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}
WEB=YES
SETUP_TYPE=13
USE_REMOVABLE_DRIVE=NO
[GLOBAL_MSI_PROPERTIES]
#==================== Common UIs: install mode
[LaunchDlg]
UI_CREATOR=LaunchDialog
UI_SOURCE=Setup\SetupAcadUi.dll
[LicenseDlg]
UI_CREATOR=LicenseDialog
UI_CONDITION=NOT ADSK_OEMPREINSTALL
[ProductSelectionDlg2]
UI_CREATOR=ProductSelectionDialog2
[ProductInfoDlg]
UI_CREATOR=ProductInfoDialog
UI_CONDITION=ADSK_LAUNCH_MODE<>"TOOLS" AND NOT ADSK_OEMPREINSTALL
[FullProgressDlg]
UI_CREATOR=FullProgressDialog
UI_INFOTAINMENT_PATH=SetupRes\Infotainment\Images
UI_INFOTAINMENT_ELAPSE=18000
[InstallCompleteDlg]
UI_CREATOR=InstallCompleteDialog
UI_CONDITION=ADSK_LAUNCH_MODE<>"DEPLOYMENT" AND ADSK_LAUNCH_MODE<>"MINIMAL_DEPLOYMENT"
#==================== Common UIs: deploy mode
[BeginDeploymentDlg]
UI_CREATOR=BeginDeploymentDialog
UI_SOURCE=Setup\DeployUi.dll
UI_CONDITION=ADSK_LAUNCH_MODE="DEPLOYMENT" OR ADSK_LAUNCH_MODE="MINIMAL_DEPLOYMENT"
[DeploymentCompleteDlg]
UI_CREATOR=DeploymentCompleteDialog
UI_CONDITION=(ADSK_LAUNCH_MODE="DEPLOYMENT" OR ADSK_LAUNCH_MODE="MINIMAL_DEPLOYMENT") AND ADSK_SETUP_SUCCEEDED
[DeploymentFailedDlg]
UI_CREATOR=DeploymentFailedDialog
UI_CONDITION=(ADSK_LAUNCH_MODE="DEPLOYMENT" OR ADSK_LAUNCH_MODE="MINIMAL_DEPLOYMENT") AND NOT ADSK_SETUP_SUCCEEDED
#==================== Common UIs: maintenance mode
[MaintenanceDlg]
UI_CREATOR=MaintenanceDialog
[AddRemoveFeaturesDlg]
UI_CREATOR=AddRemoveFeaturesDialog
UI_CONDITION=NOT ADSK_OEMPREINSTALL AND NOT REINSTALL="ALL" AND NOT REMOVE="ALL"
[RepairDlg]
UI_CREATOR=RepairDialog
UI_CONDITION=NOT ADSK_OEMPREINSTALL AND REINSTALL="ALL"
[MaintVerifyReadyDlg]
UI_CREATOR=MaintVerifyReadyDialog
[MaintCompleteDlg]
UI_CREATOR=MaintCompleteDialog
UI_CONDITION=NOT ADSK_OEMPREINSTALL AND ADSK_SETUP_SUCCEEDED
[MaintFailedDlg]
UI_CREATOR=MaintFailedDialog
UI_CONDITION=NOT ADSK_OEMPREINSTALL AND NOT ADSK_SETUP_SUCCEEDED
[OemPreinstallLicenseDlg]
UI_CONDITION=ADSK_OEMPREINSTALL="1"
[OemPreinstallProductInfoDlg]
#==================== Deploy UI Sequence
[ContentLocationPage]
UI_CREATOR=ContentLocationPage
[PathCustomizationPage]
UI_CREATOR=PathCustomizationPage
[AddAdditionalFilesPage]
UI_CREATOR=AddAdditionalFilesPage
[WorkstationSettingPage]
UI_CREATOR=WorkstationSettingPage
[ServicePackPageForDeploy]
UI_CREATOR=ServicePackPage
[ServicePackPageForInstall]
UI_CONDITION=ADSK_RUNNING_FROM_ADMIN="FALSE" AND NOT ADSK_LAUNCH_MODE="DEPLOYMENT" AND NOT ADSK_LAUNCH_MODE="MINIMAL_DEPLOYMENT"
[InfoCenterCommCenterPage]
UI_CREATOR=InfoCenterCommCenterPage
[OnlineResourcesPage]
UI_CREATOR=OnlineResourcesPage
#==================== Maya Prerequisite
[IE]
PRODUCT_NAME=Internet Explorer 7
PRODUCT_MESSAGE=SetupRes.dll;209
VC_FUNC=IeVerCheck
VC_SOURCE=Setup\SetupUi.dll
VC_PARAM=7.0.5730;7.0;1
VC_DESCRIPTION=Detecting Internet Explorer
[MSI]
PRODUCT_NAME=MSI 4.0 Runtime
EXE_PATH=3rdParty\MSI
EXE64_PATH=3rdParty\MSI
EXE_PARAM=/quiet /norestart
ROLLBACKABLE=YES
VC_FUNC=MsiVerCheck
VC_PARAM=4.0
VC_DESCRIPTION=Detecting MSI 4.0
DISKCOST=200000
DOWNLOAD_UNCOMPSIZE=47945808
DOWNLOAD_COMPSIZE=47514880
URL={DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/MSI.tar.lzma2
[VCREDIST2005SP1ATLX64]
PLATFORM=x64
PRODUCT_NAME=Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64)
EXE64_PATH=3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe
EXE_PARAM=/q:a /T:%windir%\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v %temp%\vcredist_x64_2005.log"" "
VC_FUNC=VCx64RedisCheck
VC_PARAM={6ce5bae9-d3ca-4b99-891a-1dc6c118a5fc}
ROLLBACKABLE=NO
DOWNLOAD_UNCOMPSIZE=3215280
DOWNLOAD_COMPSIZE=3172471
URL={DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/VCREDIST2005SP1ATLX64.tar.lzma2
[VCREDIST2005SP1ATLX86]
PLATFORM=ALL
PRODUCT_NAME=Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86)
EXE_PATH=3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe
EXE_PARAM=/q:a /T:%windir%\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v %temp%\vcredist_x86_2005.log"" "
VC_FUNC=VCx86RedisCheck
VC_PARAM={837b34e3-7c30-493c-8f6a-2b0f04e2912c}
ROLLBACKABLE=NO
DOWNLOAD_UNCOMPSIZE=2745256
DOWNLOAD_COMPSIZE=2701874
URL={DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/VCREDIST2005SP1ATLX86.tar.lzma2
[VCREDIST2008SP1X64]
PLATFORM=x64
PRODUCT_NAME=Microsoft Visual C++ 2008 SP1 Redistributable (x64)
EXE64_PATH=3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe
EXE_PARAM=/q
VC_PARAM={4B6C7001-C7D6-3710-913E-5BC23FCE91E6}
ROLLBACKABLE=NO
DOWNLOAD_UNCOMPSIZE=5225304
DOWNLOAD_COMPSIZE=5199628
URL={DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/VCREDIST2008SP1X64.tar.lzma2
[VCREDIST2008SP1X86]
PLATFORM=ALL
PRODUCT_NAME=Microsoft Visual C++ 2008 SP1 Redistributable (x86)
EXE_PATH=3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe
EXE_PARAM=/q
VC_PARAM={1F1C2DFC-2D24-3E06-BCB8-725134ADF989}
ROLLBACKABLE=NO
DOWNLOAD_UNCOMPSIZE=4485976
DOWNLOAD_COMPSIZE=4464859
URL={DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/VCREDIST2008SP1X86.tar.lzma2
[VCREDIST2010SP1X86]
PLATFORM=ALL
PRODUCT_NAME=Microsoft Visual C++ 2010 SP1 Redistributable (x86)
EXE_PATH=3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe
EXE_PARAM=/q /norestart
VC_PARAM={F0C3E5D1-1ADE-321E-8167-68EF0DE699A5}
IGNORE_ERROR=5100
DOWNLOAD_UNCOMPSIZE=4995416
DOWNLOAD_COMPSIZE=4970591
URL={DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/VCREDIST2010SP1X86.tar.lzma2
[VCREDIST2010SP1X64]
PLATFORM=x64
PRODUCT_NAME=Microsoft Visual C++ 2010 SP1 Redistributable (x64)
EXE64_PATH=3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe
VC_PARAM={1D8E6291-B0D5-35EC-8441-6616F567A0F7}
IGNORE_ERROR=5100
DOWNLOAD_UNCOMPSIZE=5673816
DOWNLOAD_COMPSIZE=5648792
URL={DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/VCREDIST2010SP1X64.tar.lzma2
[DIRECTX]
PLATFORM=ALL
PRODUCT_NAME=DirectX® Runtime
EXE_PATH=3rdParty\DirectX\DXSETUP.exe
EXE_PARAM=/silent
IGNORE_FAILURE=YES
DISKCOST=50000000
DOWNLOAD_UNCOMPSIZE=105305071
DOWNLOAD_COMPSIZE=101735929
URL={DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/DIRECTX.tar.lzma2
[DOTNET4]
PLATFORM=ALL
PRODUCT_NAME=.NET Framework Runtime 4.0
EXE_PATH=3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe
EXE_PARAM=/q
VC_FUNC=DotnetVerify
VC_PARAM=.NET Framework 4 Full
VC_DESCRIPTION=Detecting .NET 4.0 Runtime
DISKCOST=80000000
IGNORE_FAILURE=YES
DOWNLOAD_UNCOMPSIZE=100557536
DOWNLOAD_COMPSIZE=99941379
URL={DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/DOTNET4.tar.lzma2
[DOTNET4KB2468871]
PLATFORM=ALL
PREREQUISITE=DOTNET4
PRODUCT_NAME=.NET Framework Runtime 4.0 KB2468871
EXE_PATH=3rdParty\NET\4\wcu\dotNetFramework\NDP40-KB2468871-v2-x86.exe
EXE64_PATH=3rdParty\NET\4\wcu\dotNetFramework\NDP40-KB2468871-v2-x64.exe
VC_PARAM=.NET Framework 4 KB2468871
VC_DESCRIPTION=Detecting .NET Framework Runtime 4.0 KB2468871
DISKCOST=80000000
DOWNLOAD_UNCOMPSIZE=100557536;100557536
DOWNLOAD_COMPSIZE=99941379;99941379
URL={DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/DOTNET4.tar.lzma2;{DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/DOTNET4.tar.lzma2
[DOTNET]
#== This section is required by the framework to display a package level alert_
#== _if the system does not contain a minimum version of NET (set in VC_PARAM below)
PLATFORM=ALL
VC_PARAM=4.0.30319
[_DOTNET35SP1]
PLATFORM=ALL
PRODUCT_NAME=.NET Framework Runtime 3.5 SP1
EXE_PATH=3rdParty\NET\35SP1\wcu\dotNetFramework\Install35Net.exe
VC_SOURCE=Setup\SetupUI.dll
VC_PARAM=.NET Framework 3.5 SP1
IGNORE_FAILURE=NO
VC_DESCRIPTION=Detecting .NET Runtime 3.5 SP1
DISKCOST=80000000
DOWNLOAD_UNCOMPSIZE=242857352
DOWNLOAD_COMPSIZE=231446453
URL={DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/_DOTNET35SP1.tar.lzma2
[MSXML]
PRODUCT_NAME=MSXML 6
PLATFORM=NATIVE
EXE_PATH=3rdParty\x64\msxml6\msxml6_x64.msi
IGNORE_FAILURE=YES
VC_FUNC=MsxmlVerCheck
VC_PARAM=6.0
[Maya]
PLATFORM=x64
PREREQUISITE=IE;MSI;VCREDIST2005SP1ATLX86;VCREDIST2008SP1X86;VCREDIST2010SP1X86;VCREDIST2005SP1ATLX64;VCREDIST2008SP1X64;VCREDIST2010SP1X64;DOTNET4;DOTNET4KB2468871;_DOTNET35SP1;DIRECTX
SUBCOMPONENT=MentalRayPlugIn;MatchMover;Composite;Backburner;DirectConnect
PRODUCT_NAME=Autodesk® Maya® 2014
PRODUCT_ICON=SetupRes\maya.ico
PRODUCT_INSTALLED_INFO_MSG= SetupMnEUiRes.dll;101
PRODUCT_INSTALLED_INFO_URL= SetupMnEUiRes.dll;104
PRODUCT_MESSAGE=SetupMnEUiRes.dll;507
EULA_PATH=eula
COMPRESSED=YES
LOG=%tmp%\Maya2014_x64_Install.log
EXE_PATH=x64\Maya\Maya2014.msi
EXE_PARAM=
ACTION=INSTALL
REMOVE_PATH=
USE_EXTERNAL_UI=YES
ALLOW_ADD_REMOVE=NO
USE_MEDIA=NO
UI_SEQUENCE=AddAdditionalFilesPage;ServicePackPageForDeploy;ServicePackPageForInstall
MAINTENANCE_UI_SEQUENCE=MaintenanceDlg;AddRemoveFeaturesDlg;RepairDlg;MaintVerifyReadyDlg;FullProgressDlg;MaintCompleteDlg;MaintFailedDlg
LAUNCH_EXE=maya.exe
ADMIN_INSTALL=YES
EXTRA_FILES=maya;x64\Maya\*:x64\Maya\Program Files\Autodesk\Maya2014\icons\*.png:x64\Maya\Program Files\Autodesk\Maya2014\resources\*.png
LPMODE=MLD_ADR
AVAILABLELANGUAGES=en-US;ja-JP;zh-CN
DISK_PROMPT=SetupMnEUiRes.dll;394;394
DISK_LABEL=Maya2014;Maya2014
[MatchMover]
PLATFORM=x64
PRODUCT_NAME=Autodesk® MatchMover™ 2014
PRODUCT_ICON=SetupRes\matchmover.ico
PRODUCT_MESSAGE=SetupMnEUiRes.dll;515
EULA_PATH=eula
COMPRESSED=YES
LOG=%tmp%\MatchMover2014_x64_Install.log
EXE_PATH=x64\MatchMover\MatchMover2014.msi
EXE_PARAM=
ACTION=INSTALL
IGNORE_FAILURE=YES
REMOVE_PATH=
USE_EXTERNAL_UI=YES
USE_MEDIA=NO
LAUNCH_EXE=matchmover.exe
ADMIN_INSTALL=YES
EXTRA_FILES=maya;x64\MatchMover\*
DOWNLOAD_UNCOMPSIZE=133138702
DOWNLOAD_COMPSIZE=132899941
URL={DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/MatchMover.tar.lzma2
[Composite]
PLATFORM=x64
PRODUCT_NAME=Autodesk® Composite 2014
PRODUCT_ICON=SetupRes\composite.ico
PRODUCT_MESSAGE=SetupMnEUiRes.dll;516
EULA_PATH=eula
COMPRESSED=YES
LOG=%tmp%\Composite2014_x64_Install.log
EXE_PATH=x64\Cp\Composite2014.msi
EXE_PARAM=
ACTION=INSTALL
IGNORE_FAILURE=YES
REMOVE_PATH=
USE_EXTERNAL_UI=YES
USE_MEDIA=NO
LAUNCH_EXE=
ADMIN_INSTALL=YES
EXTRA_FILES=maya;x64\Cp\*
DOWNLOAD_UNCOMPSIZE=186629244
DOWNLOAD_COMPSIZE=184772077
URL={DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/Composite.tar.lzma2
[MentalRayPlugIn]
PLATFORM=x64
PRODUCT_NAME=mental ray® renderer for Autodesk® Maya® 2014
PRODUCT_ICON=SetupRes\Maya.ico
#PRODUCT_MESSAGE=SetupMnEUiRes.dll;516
EULA_PATH=eula
COMPRESSED=YES
LOG=%tmp%\MentalRayPlugIn2014_x64_Install.log
EXE_PATH=x64\MentalRayPlugIn\MentalRayPlugIn2014.msi
EXE_PARAM=
ACTION=INSTALL
IGNORE_FAILURE=YES
REMOVE_PATH=
USE_EXTERNAL_UI=YES
USE_MEDIA=NO
LAUNCH_EXE=
ADMIN_INSTALL=NO
EXTRA_FILES=maya;x64\MentalRayPlugIn\*
DISKCOST=115000000
DOWNLOAD_UNCOMPSIZE=114717990
DOWNLOAD_COMPSIZE=19536999
URL={DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/MentalRayPlugIn.tar.lzma2
[Backburner]
PLATFORM=ALL
PRODUCT_NAME=Autodesk® Backburner 2014
PRODUCT_MESSAGE=SetupMnEUiRes.dll;533
ACTION=INSTALL
EXE_PATH=x64\BackBurner\BackburnerCIF.exe
EXE_PARAM=SETUP_PACKAGENAME="Autodesk Maya 2014" SETUP_PACKAGECODE="{44FFD99B-4877-4732-AA33-2FD3D7B622D2}"
ALLOW_ADD_REMOVE=NO
IGNORE_FAILURE=YES
ADMIN_INSTALL=NO
EXTRA_FILES=maya;x64\Backburner\*
DISKCOST=15000000
DOWNLOAD_UNCOMPSIZE=11223760
DOWNLOAD_COMPSIZE=6087926
URL={DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/Backburner.tar.lzma2
[DirectConnect]
PLATFORM=ALL
PREREQUISITE=IE;MSI;VCREDIST2005SP1ATLX86;VCREDIST2008SP1X86;VCREDIST2010SP1X86;VCREDIST2005SP1ATLX64;VCREDIST2008SP1X64;VCREDIST2010SP1X64;MSXML;DIRECTX
PRODUCT_NAME=Autodesk® DirectConnect 2014
PRODUCT_MESSAGE=SetupMnEUiRes.dll;534
EULA_PATH=eula
COMPRESSED=YES
LOG=%tmp%\DirectConnect2014_x64_Install.log
EXE_PATH=x64\DirectConnect\AutodeskDirectConnect8.0.msi
EXE_PARAM=
ALLOW_ADD_REMOVE=NO
ACTION=INSTALL
IGNORE_FAILURE=YES
REMOVE_PATH=
ROLLBACKABLE=YES
USE_EXTERNAL_UI=YES
USE_MEDIA=NO
LAUNCH_EXE=
#ADMIN_INSTALL=NO
#EXTRA_FILES=maya;x64\DirectConnect\*
#==================== Supplement Tools
DOWNLOAD_UNCOMPSIZE=1207187580
DOWNLOAD_COMPSIZE=295511804
URL={DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/DirectConnect.tar.lzma2
[NLM]
PRODUCT_NAME=Network License Manager
PRODUCT_GROUP=Network License Components
EULA_PATH=eula
LOG=%tmp%\NLM_x64_Install.log
EXE_PATH=x64\Tools\NLM\NLM.msi
INSTALL_TYPE=4
ACTION=INSTALL
IGNORE_FAILURE=YES
SUMMARY_FUNC=LoadSummary_Simple
SUMMARY_SOURCE=Setup\SetupAcadUi.dll
ALLOW_ADD_REMOVE=NO
[Maya_en-US]
DOWNLOAD_UNCOMPSIZE=879026571
DOWNLOAD_COMPSIZE=868303935
URL={DE3F75AA-44EA-4ECA-8677-F9DF086ADD0C}/Maya_en-US.tar.lzma2
[Maya_ja-JP]
[Maya_zh-CN]
Message 14 of 18
ryeppe
UP please, same problem !!!
I can't install Maya 2014 yet !
Can you tell differents steps to install maya in this computer please ?? (maya install works in other computers)
thank you for helping, I really need maya to work...
Message 15 of 18
TravisNave
in reply to: ryeppe
I would just comment out the PREREQUISITE line altogether with a pound (#) and run setup.exe again.
Autodesk Forums:
Message 16 of 18
ryeppe
I tested it do not works...
Do I need microsoft visual c++ 2005 to run maya installation??
(i can t install c++ 2005....----> error)
Message 17 of 18
TravisNave
in reply to: ryeppe
Yes.  You need it.  Can you not install it manually from Microsoft?
Autodesk Forums:
Message 18 of 18
wittekonijn
same probleem here with inventor and .net3.5
why is this file in the setup.ini if the thing is not needed for inventor to run
i installed the .net3.5 manualy but nothing changed
get the message that ther is no intenet connection (broadband)and somme files could not been downloaded
will now delete the .net3.5 in the in i file and then try to install inventor again
regards raf
Administrator Productivity
