Installation & Licensing
software does not reconize the licensing server
5 REPLIES 5
uchicago
264 Views, 5 Replies
– I loaded in the new license file and the license service is now running.
However the software cannot find the license server when I start the applications….
5 REPLIES 5
DarrenP
in reply to: uchicago
try using the ip address of the license server
http://upandready.typepad.com/up_and_ready/2013/03/network-licensing-flexnet-license-finder-.html?ut...
DarrenP
Darin.Green
Disable the firewall on the server where the license manager is configured. Once its disabled, check to see if the application open. If the application opens, then you'll need to open ports 2080 and 27000-27009 for incomming.
Hope that help
If this information was helpful, please consider using the Accept Solution
TravisNave
in reply to: Darin.Green
Right.  You can test this with Internet Explorer:
http://fac-beast01:27000
http://fac-beast01:2080
Both should exhibit some jargon in IE if the ports are open.  If not, definitely firewall.  Also, try to PING fac-beast01 and make sure it responds with an IPv4 address and not the new IPv6 scheme.
Autodesk Forums:
uchicago
Ok used your IE URL's and got back the below on both...
W?-60W?-60W?-60
W?-60W?-60W?-60
Tried to ping fac-beast01 and got the following reply....
[cid:image001.png@01CE668D.2206DCA0]
Scott Stocking, GISP
The University of Chicago
[FS logo]
5555 S. Ellis Avenue
Chicago, IL 60637
Office: 773.834.0523
Cell: 630.388.9083
t-9stock@uchicago.edu
TravisNave
The results of the IE are good.  The picture though did not come thru.
http://forums.autodesk.com/t5/Test/How-to-take-a-screen-capture-and-upload-it/m-p/3467392
So we at least know it is not a firewall issue.  Could still be an IPv6 one.  Repost your screencap.
Autodesk Forums:
Administrator Productivity
