I have installed the 2012 upgrade. When I open the program I get the following error:
The security system (softlock license manager) is not functuining or is improperly installed.
The program then shuts down. Any ideas?
I am experiencing similar issues with AutoCAD 2013. The security problem occurs the first time I access the program after a reinstall. After another boot, the program suddenly closes itself while loading; this repeats indefinitely unless I reinstall the product, and then the cycle begins again. If it is relevant, can you clarify exactly how to change the neccesary permissions and location of the license files? It would also be helpful if you are familiar with the program closing itself.
Awesome!!! it worked!! i found the "flexnet" folder placed in on the desktop and all Autodesk software worked like nothing had ever happened. Wow, that was wild..thx.
Ps. using Windows 7
Still late
I tried this deleting the "above" files but go to start The "cad" program and it just shuts off. having said that all my other programs with the suite still work.
So I just cant use the AutoCad 2013 and have no place to put a serial number.
Any other Ideas?
thanks
It also can be, that in the system configuration of Windows the Service "Flexnet Licencing Service" is deactivated (Window 7). If its activated all programms of Autodesk run.
Best regards.
Lena
I am having this same problem with Architecture 2014 on windows 8.1, and none of these solutions seem to work, can you help?
Despite it working perfectly the first time around, I experienced similar problems with the Security system / Softlock license manager error when I was forced to reinstall my student version of Autocad Architecture 2014 on my new Windows 8 laptop. I tried many of the solutions that are spoken of here including attmepying multiple clean reinstalls and trying to deal with the FLEXnet files. However none of these worked until today when I spotted the solution to my problem on this thread.
It seems that all you have to do is:
1) Close any running applications or files or internet browsers
2) Cut the actual "FLEXnet" file ( found at C:\ProgramData )
3) Paste this file onto your desktop
4) Startup AutoCad and it should be running without issue
Thank you all for your help and in turn I hope this can solve this irriatating problem for anyone else who may be struggling with it.
i am facing the same problems at one of our customer locations. none of the methods mentioned in the support and dicussion groups are working out Any solutions!!
Buen día.
Instalé Autocad Civil 2014 con la licencia para estudiantes y me dice que la instalación está bien. Pero cuando lo abro el programa me sale un mensaje de "softlock license manager error messege" que está mal instalado. No se como resolver ésto, necesito su ayuda. Desde ya muy agradecido.
Saludos cordiales.
I installed AUTOCAD 2013 and I've receved the soft license manager error. I am running a stand alone Windows 8 pc. I can't seem to find any solutions. I've uininstalled, reinstalled, and used all of the different methods of installation that AUTODESK has to offer. Does anyone have a solution for this issue?
i just updated to windows 8.1 and this caused my autoCAD 2014 to have softlock license manager error.. i tried to to do the steps but may i know please where the flexnet file could be located in windows 8.1?? i just can't seem to find it.. please.. need help..
Did anybody manage to solve this issue?
I have autocad 2014 running perfectly on widows 8 and when I updated to 8.1 i started getting softlock license manager error.
Any solution posted for this problem?
I had the same problem to my AutoCAD 2014; Windows 7 and nothing worked. However, when I moved the FLEXnet directory (C:ProgramData) to my Desktop and ran the Repair program (under Uninstall Program) it worked. Repair recreated the FLEXnet directory with the associated files.
Fix Autocad 2013 in Windows 8.1
- Deactivate Internet and Antivirus
- Uninstall all product autocad
- Ccleaner
- Delet C:\ProgramData\FLEXnet folder
- Restart
- Install Autocad Administrator privileges
Following the steps the problem was solved in WINDOWS 8.1 - Does not work if you only delete the "flex" folder.
From Playa del Carmen
Hi @Anonymous and welcome to the Autodesk Community!
Did you try the Accepted Solution for this issue? How did it go? Did you see any changes? Please reply with further details. Thanks!
