Installation & Licensing
softlock license manger error message
45 REPLIES 45
Message 1 of 46
60836 Views, 45 Replies
I have installed the 2012 upgrade. When I open the program I get the following error:
The security system (softlock license manager) is not functuining or is improperly installed.
The program then shuts down. Any ideas?
45 REPLIES 45
Message 2 of 46
hashim.mundol
Is this Autocad 2012 ?
please try a clean installation of Autocad as admin
http://usa.autodesk.com/getdoc/id=TS75218
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Autodesk, Inc.
Message 3 of 46
I brought this to Autodesk tech. support. I have had issues with running 2011 Autodesk products. One day all was working fine. The next morning none of my autocad programs would run. After many hours of trying different suggetions from tech support we were about ready to re-format the hard drive and start new. When the 2012 update became available we figured one last try before the re-format. This is when the softlock error poped up. I recieved the following message from Autodesk in response to the softlock issue:
"Softlock License Manager Errors were usually seen with the older version of AutoCAD products (releases older than 2008) and the typical cause of the error was restricted permissions on licensing folder or some corruption with the license file.
The standalone license file location on Windows 7 is C:\ProgramData\FLEXnet and standalone license file name is similar to adskflex_00691b00_tsf.data and adskflex_00691b00_tsf.data_backup.001.  These files are encrypted files and basically keep activation information.  Please try giving Everyone full control permissions to the folder and move adskflex data files you find there to another folder (e.g. Desktop) and let me know if this helps."
By doing this all of my Autocad programs work, even the 2011 products which started this process. After all the things we tried it seems it was a permission's problem. I have had many permission issues since installing Windows 7.
Glad this one is behind us.
Message 4 of 46
hashim.mundol
thank you for sharing the solution with the community 🙂
Hashim Mundol
Autodesk, Inc.
Message 5 of 46
Jessup
Thank you for posting that solution to the forums; it is the only one I have found for this error message in the 2012 products.
Here are the paths for those files in Windows XP and Windows Vista, as well:
On Vista or Windows 7:
C:\ProgramData\FLEXnet\adskflex_00691b00_tsf.data
C:\ProgramData\FLEXnet\adskflex_00691b00_tsf.data.backup
On Windows XP:
C:\Documents and Settings\All Users\Application Data\FLEXnet\adskflex_00691b00_tsf.data
C:\Documents and Settings\All Users\Application Data\FLEXnet\adskflex_00691b00_tsf.data.backup
Best regards,
Jessup H.
Support Specialist
Product Support
Autodesk, Inc.
Tags (1)
Message 6 of 46
john
in reply to: Jessup
Having similar issues on XP but can't find "Application Data" folder with .data file in location specified.  Where else could it be?
Message 7 of 46
TravisNave
in reply to: john
It's a hidden folder.  You can either turn hidden folders and files on within your explorer properties or you can put the path directly into your address bar and get there.
Autodesk Forums:
Message 8 of 46
leaveAlone
in reply to: Jessup
I am having this problem as well, however, I do not know how to give everyone full rights to these files on XP. Any help would be greatly appreciated. Thanks!
Message 9 of 46
I am experiencing the same problem with my autocad electrical installation. I am running XP SP3 and have ACE2011 and ACE2012. Neither will load and ACE2011 shows no error. The splash screen pops up and then goes away and nothing. ACE2012 at least lets me know that the softlock license manager is not functioning.
I tried the fix suggested in the tread with no luck. Any other ideas or suggestions?
Jeff
Tags (2)
Message 10 of 46
So... if this solution doesn't fix the problem then what else could it be? I have found a few other references to other fixs for this problem but nothing is working. I have a stand alone license and can't get any work done. 😞
Message 11 of 46
hashim.mundol
Have you tried delete the c:\programdata\autodesk\adlm folder after uninstalling all Autodesk programs ?
also
please try to install the software in diagnostics mode as described here
if you still have issues please post
c:\programdata\autodesk\adlm\*adlm*.log files.
Hashim Mundol
Autodesk, Inc.
Message 12 of 46
in reply to: hashim.mundol
I uninstalled ACE2011 and ACE2012 cleaned out the registry and reinstalled ACE2012 only and all seems ok.
Message 13 of 46
c.bergthold
in reply to: Jessup
I'm seeing this error on a users computer with a network license. It is my understanding that the above solution is for a standalone license. Am I correct? Any suggestions?
Cory
Cory
Message 14 of 46
see if FlexNET service is started.
Message 15 of 46
c.bergthold
Flexnet service is started, all other users have no problems getting a license.
Cory
Cory
Message 16 of 46
Doing a reinstall at the moment
thanks
Message 17 of 46
hi,
I´m installing autocad mechanic 2012 and i get the same problem.
I´ve tried everything here and i still get the same error message an then it shuts down.
I´m using windows 7 home premium
Can anyone help?
Message 18 of 46
c.bergthold
I tried everything I could think of and ended up formating the hard drive and starting over. If I remember correctly I read somewhere it was a registry problem. Good luck.
Cory
Message 19 of 46
TravisNave
For additional information, please consider using Search to assist in your resolution:
Search Autodesk.com
Search Autodesk Discussion Groups
Search Up and Ready Blog
Search Autodesk WikiHelp
Autodesk Forums:
Message 20 of 46
JiThink
There's only "adskflex_00691b00_event.txt" in my "C:\ProgramData\FLEXnet". Any ideas?
Administrator Productivity
