Installation & Licensing
Smoke 2013 error "Failed to Initialize Stone + Wire connection
2 REPLIES 2
chaoticpit
2618 Views, 2 Replies
Hello.Sorry my English is not so good, I hope you understand.
I have message error "Failed to Initialize Stone + Wire connection when I start smoke 2013. It worked for about 1 month, now does not.
I have I think static IP address. I have DHCP modem.
My Mac is iMac late 2012.
I have generous support from Area, but not succes yet.
I have logged many errors messages, but no results so far.
I reinstall OS X (but the new wy, without complete 100% wipe of hard drive).
I then reinstalled Smoke 2013. Still, same message.
Do I need to clean my harddrive 100%, then start over? I have hard time to do that, as I work on shared computer.
Please help if you have suggestion.
Sincerely,
Pitchapa
2 REPLIES 2
Robert.Adam
in reply to: chaoticpit
Hi
Please refer to the answer I gave you at the top of this AREA forum page:
http://area.autodesk.com/forum/autodesk-smoke/smoke-2013/error-failed-to-initialize-stone-+-wire-con...
Best regards,
Robert Adam
Autodesk Premium Support.
Robert Adam
Program Manager
OSHASMOKE
in reply to: Robert.Adam
Hi Adam, I think I found the issue.
Mine was doing the same thing since 6 months, just solved.( OS X Mountain Lion 10.8)
Changed only the IP 127.0.0.1 to the new IP under network in system preferences. and restart you Mac
Easy as Baby step, nothing else.
Step 1 – Open the Terminal.app
Either start typing Terminal in the Spotlight search, or goto Applications > Utilities > Terminal.
Step 2 – Open the host file
Open the hosts file by typing the following in the Terminal window:
sudo nano /private/etc/hosts
Type your user password when prompted.
Step 3 – Edit the hosts file
The hosts file contains some comments (lines starting with the # symbol), as well as some default hostname mappings (e.g. 127.0.0.1 – local host). Simply append your new mappings underneath the default ones.
Step 4 – Save the hosts file
When done editing the hosts file, press Control+o to save the file.
Press Enter on the filename prompt, and
Control-x to exit the editor.
Step 5 – Flush the DNS cache
You can use a simple Terminal command to flush the DNS cache, and have your host file changes take immediate effect. Using the open Terminal window, then the following command:
dscacheutil -flushcache
Your new mappings should now take effect.
Administrator Productivity
