Installation & Licensing
Slow Print Dialogs - Permissions Issue
2 REPLIES 2
rfeldman
220 Views, 2 Replies
I have a client who is experiencing slow print dialogs (they take 10-15 seconds to appear) with AutoCAD 2006 on a Windows 2000 Server network. Support article #TS62597 says that one cause of the symptom is user profile or file permission problems. I have logged on as administrator as suggested in the article and confirmed that the dialogs appear with normal speed, so I think the problem is with profiles or permissions.
My question is: What should I look for in the user profile or file permissions that would cause the slow print dialogs? One user is simply a member of the generic Users group, while another, who is also experiencing the problem, is a member of both Users and Administrators. When I log on to either computer with a 3rd (User) account, the print dialogs appear after a normal short delay.
2 REPLIES 2
TravisNave
in reply to: rfeldman
Do this...
Pull out the ethernet cable from your computer and try to print. I bet your dialog box pops up immediately.
Therefore, you should install your network printer as a local printer using an IP port with the network address of your printer/JetDirect. Using it as a network shared printer causes unnecessary overhead that will cause your print dialog to be slow.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
See also this :
http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=2883747&linkID=2475323
(Shortcut or path not found.)
Franck Hervet
www.aricad.fr
a écrit dans le message de news:
5092427@discussion.autodesk.com...
Do this...
Administrator Productivity
