All,
Does anyone know what Windows setting is stored at byte 17 in the ShellState
registry setting?
For example, I have found that byte 5 changes when I change the following
setting:
Recycle Bin Properties > Global > "Display delete confirmation dialog".
Thanks!
Chris
"Jimmy B" wrote in message
news:0BA71698D3E26CD171AD7550FB319A52@in.WebX.maYIadrTaRb...
> Solution at last!
> I hunted this down. I don't know what else this setting is for but by
> changing it everything works fine. Do you know what this byte do?
> Set the two-digit value in the 17:th byte to 00.
> Observe that you have to manually change this one byte in REGEDIT. You
have
> to restart AutoCAD to have the effect.
> Correct key below:
> [HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer]
"ShellState"=hex:24,00,00,00,20,28,00,00,00,00,00,00,00,00,00,00,00,00,00,00
> 01,00,00,00,0a,00,00,00,00,00,00,00,00,00,00,00
> Erroneous key below:
"ShellState"=hex:24,00,00,00,73,a8,00,00,00,00,00,00,00,00,00,00,05,00,00,00
> Best Regards, Jimmy B
> CAD/Database Manager at www.pharmadule-emtunga.com
> Take a look at the trial version of SmartPurger or download some freeware
at
> http://jtbworld.vze.com
> news:FE15478C43D89783F584F78DF58C3FE4@in.WebX.maYIadrTaRb...
> > Hi,
> > Could anyone give me some hint on how to solve this tricky problem?
> > I have Windows 2000 and AutoCAD 2002. When I first installed Windows
2000
> > and then AutoCAD 2002 there where no problem. But after a while, I have
> > installed and uninstalled plenty of programs, the open dialog box takes
> > forever to populate.
> > I have used File Monitor from www.systeminternals.com and found out that
> > when it takes forever AutoCAD is looking at every file in the folder. On
> an
> > instalation where there is no problem AutoCAD is not looing at every
file
> > like this. It must be something that is triggering AutoCAD to do this.
But
> I
> > don't know what that is.
> > It looks like the IRP_MJ_CREATE process really slowes it down.
> > Below is from the log:
> > NO Time Process Request Path Result Other
> > 4782 0.00023020 acad.exe:1376 IRP_MJ_CREATE R:\4108\ SUCCESS Attributes:
> Any
> > Options: Open Directory
> > 4783 0.12127240 acad.exe:1376 IRP_MJ_DIRECTORY_CONTROL R:\4108\ SUCCESS
> > FileBothDirectoryInformation: 003.dwg
> > 4784 0.00003911 acad.exe:1376 IRP_MJ_CLEANUP R:\4108\ SUCCESS
> > 4785 0.00033021 acad.exe:1376 IRP_MJ_CLOSE R:\4108\ SUCCESS
> > 4786 0.00024193 acad.exe:1376 IRP_MJ_CREATE R:\4108\ SUCCESS Attributes:
> Any
> > 4787 0.01179005 acad.exe:1376 IRP_MJ_DIRECTORY_CONTROL R:\4108\ SUCCESS
> > FileBothDirectoryInformation: 004.dwg
> > 4788 0.00016203 acad.exe:1376 IRP_MJ_CLEANUP R:\4108\ SUCCESS
> > 4789 0.00018382 acad.exe:1376 IRP_MJ_CLOSE R:\4108\ SUCCESS
> > 4790 0.00000223 acad.exe:1376 FASTIO_QUERY_OPEN R:\4108\003.dwg FAILURE
> > 4791 0.00259614 acad.exe:1376 IRP_MJ_CREATE R:\4108\003.dwg SUCCESS
> > Attributes: Any Options: Open
> > 4792 0.00099789 acad.exe:1376 IRP_MJ_CLOSE R:\4108\003.dwg SUCCESS
> > 4793 0.00000196 acad.exe:1376 FASTIO_QUERY_BASIC_INFO R:\4108\003.dwg
> > FAILURE
> > 4794 0.00002933 acad.exe:1376 IRP_MJ_QUERY_INFORMATION R:\4108\003.dwg
> > SUCCESS FileBasicInformation
> > 4795 0.00012432 acad.exe:1376 IRP_MJ_CLEANUP R:\4108\003.dwg SUCCESS
> > 4796 0.00029920 acad.exe:1376 IRP_MJ_CLOSE R:\4108\003.dwg SUCCESS
> > 4797 0.02038555 acad.exe:1376 IRP_MJ_CREATE R:\4108\003.dwg SUCCESS
> > Attributes: N Options: Open
> > 4798 0.00004721 acad.exe:1376 IRP_MJ_READ C:\WINNT\CSC\00000001 SUCCESS
> > Offset: 0 Length: 4096
> > 4799 0.00059728 acad.exe:1376 IRP_MJ_QUERY_INFORMATION R:\4108\003.dwg
> > SUCCESS FileStreamInformation
> > 4800 0.00003017 acad.exe:1376 IRP_MJ_QUERY_INFORMATION R:\4108\003.dwg
> > 4801 0.00333953 acad.exe:1376 IRP_MJ_READ R:\4108\003.dwg SUCCESS
Offset:
> 0
> > Length: 24
> > 4802 0.00319873 acad.exe:1376 IRP_MJ_READ* R:\4108\003.dwg SUCCESS
Offset:
> 0
> > Length: 4096
> > 4803 0.01381656 acad.exe:1376 IRP_MJ_CREATE
> > R:\4108\003.dwg:Raec25ph4sudbf0hAaq5ehw3Nf:$DATA FILE NOT FOUND
> Attributes:
> > N Options: Open
> > 4804 0.00009554 acad.exe:1376 IRP_MJ_CLEANUP R:\4108\003.dwg SUCCESS
> > 4805 0.00024193 acad.exe:1376 IRP_MJ_CREATE R:\4108\003.dwg SUCCESS
> > 4806 0.00093057 acad.exe:1376 IRP_MJ_QUERY_INFORMATION R:\4108\003.dwg
> > 4807 0.00066824 acad.exe:1376 IRP_MJ_QUERY_INFORMATION R:\4108\003.dwg
> > 4808 0.00020841 acad.exe:1376 IRP_MJ_READ R:\4108\003.dwg SUCCESS
Offset:
> 0
> > Length: 24
> > 4809 0.01369895 acad.exe:1376 IRP_MJ_CREATE
> Attributes:
> > N Options: Open
> > 4810 0.01348607 acad.exe:1376 IRP_MJ_CREATE
> > R:\4108\003.dwg\:{4c8cc155-6c1e-11d1-8e41-00c04fb9386d}:$DATA FILE NOT
> FOUND
> > 4811 0.01341148 acad.exe:1376 IRP_MJ_CREATE
> > R:\4108\003.dwg\:SummaryInformation:$DATA FILE NOT FOUND Attributes: N
> > Options: Open
> > 4812 0.01337544 acad.exe:1376 IRP_MJ_CREATE
> > R:\4108\003.dwg\:Docf_SummaryInformation:$DATA FILE NOT FOUND
Attributes:
> N
> > Options: Open
> > 4813 0.01347238 acad.exe:1376 IRP_MJ_CREATE
> > Options: Open
> > 4814 0.01371934 acad.exe:1376 IRP_MJ_CREATE
Attributes:
> N
> > Options: Open
> > 4815 0.01354194 acad.exe:1376 IRP_MJ_CREATE
> > Options: Open
> > 4816 0.01362073 acad.exe:1376 IRP_MJ_CREATE
Attributes:
> N
> > Options: Open
> > 4817 0.01338829 acad.exe:1376 IRP_MJ_CREATE
> > R:\4108\003.dwg\:DocumentSummaryInformation:$DATA FILE NOT FOUND
> > 4818 0.01355787 acad.exe:1376 IRP_MJ_CREATE
> > R:\4108\003.dwg\:Docf_DocumentSummaryInformation:$DATA FILE NOT FOUND
> > 4819 0.01358022 acad.exe:1376 IRP_MJ_CREATE
> > Options: Open
> > 4820 0.01330169 acad.exe:1376 IRP_MJ_CREATE
Attributes:
> N
> > Options: Open
> > 4821 0.01346875 acad.exe:1376 IRP_MJ_CREATE
> > Options: Open
> > 4822 0.01358357 acad.exe:1376 IRP_MJ_CREATE
Attributes:
> N
> > Options: Open
> > 4823 0.02074817 acad.exe:1376 IRP_MJ_CREATE
> > R:\4108\003.dwg\:SebiesnrMkudrfcoIaamtykdDa:$DATA FILE NOT FOUND
> > 4824 0.01414593 acad.exe:1376 IRP_MJ_CREATE
> > R:\4108\003.dwg\:Docf_SebiesnrMkudrfcoIaamtykdDa:$DATA FILE NOT FOUND
> > 4825 0.00008465 acad.exe:1376 IRP_MJ_CLEANUP R:\4108\003.dwg SUCCESS
> > 4826 0.00000223 acad.exe:1376 FASTIO_QUERY_OPEN R:\4108\004.dwg FAILURE
> > 4827 0.00252825 acad.exe:1376 IRP_MJ_CREATE R:\4108\004.dwg SUCCESS
> > 4828 0.00104538 acad.exe:1376 IRP_MJ_CLOSE R:\4108\004.dwg SUCCESS
> > 4829 0.00000223 acad.exe:1376 FASTIO_QUERY_BASIC_INFO R:\4108\004.dwg
> > FAILURE
> > 4830 0.00017209 acad.exe:1376 IRP_MJ_QUERY_INFORMATION R:\4108\004.dwg
> > 4831 0.00003911 acad.exe:1376 IRP_MJ_CLEANUP R:\4108\004.dwg SUCCESS
> > 4832 0.00031596 acad.exe:1376 IRP_MJ_CLOSE R:\4108\004.dwg SUCCESS
> > 4833 0.01883088 acad.exe:1376 IRP_MJ_CREATE R:\4108\004.dwg SUCCESS
> > 4834 0.00004637 acad.exe:1376 IRP_MJ_READ C:\WINNT\CSC\00000001 SUCCESS
> > 4835 0.00070065 acad.exe:1376 IRP_MJ_QUERY_INFORMATION R:\4108\004.dwg
> > 4836 0.00002933 acad.exe:1376 IRP_MJ_QUERY_INFORMATION R:\4108\004.dwg
> > 4837 0.00148203 acad.exe:1376 IRP_MJ_READ R:\4108\004.dwg SUCCESS
Offset:
> 0
> > Length: 24
> > 4838 0.00135548 acad.exe:1376 IRP_MJ_READ* R:\4108\004.dwg SUCCESS
Offset:
> 0
> > Length: 4096
> > 4839 0.01311144 acad.exe:1376 IRP_MJ_CREATE
> > R:\4108\004.dwg:Raec25ph4sudbf0hAaq5ehw3Nf:$DATA FILE NOT FOUND
> Attributes:
> > N Options: Open
> > 4840 0.00008940 acad.exe:1376 IRP_MJ_CLEANUP R:\4108\004.dwg SUCCESS
> > 4841 0.00023858 acad.exe:1376 IRP_MJ_CREATE R:\4108\004.dwg SUCCESS
> > 4842 0.00122613 acad.exe:1376 IRP_MJ_QUERY_INFORMATION R:\4108\004.dwg
> > 4843 0.00063500 acad.exe:1376 IRP_MJ_QUERY_INFORMATION R:\4108\004.dwg
> > 4844 0.00020617 acad.exe:1376 IRP_MJ_READ R:\4108\004.dwg SUCCESS
Offset:
> 0
> > Length: 24
> > 4845 0.01357072 acad.exe:1376 IRP_MJ_CREATE
> Attributes:
> > N Options: Open
> > 4846 0.01364894 acad.exe:1376 IRP_MJ_CREATE
> > R:\4108\004.dwg\:{4c8cc155-6c1e-11d1-8e41-00c04fb9386d}:$DATA FILE NOT
> FOUND
> > 4847 0.01353384 acad.exe:1376 IRP_MJ_CREATE
> > R:\4108\004.dwg\:SummaryInformation:$DATA FILE NOT FOUND Attributes: N
> > Options: Open
> > 4848 0.01473874 acad.exe:1376 IRP_MJ_CREATE
> > R:\4108\004.dwg\:Docf_SummaryInformation:$DATA FILE NOT FOUND
Attributes:
> N
> > Options: Open
> > 4849 0.01411185 acad.exe:1376 IRP_MJ_CREATE
> > Options: Open
> > 4850 0.01349473 acad.exe:1376 IRP_MJ_CREATE
Attributes:
> N
> > Options: Open
> > 4851 0.01452056 acad.exe:1376 IRP_MJ_CREATE
> > Options: Open
> > 4852 0.01366654 acad.exe:1376 IRP_MJ_CREATE
Attributes:
> N
> > Options: Open
> > 4853 0.01318715 acad.exe:1376 IRP_MJ_CREATE
> > R:\4108\004.dwg\:DocumentSummaryInformation:$DATA FILE NOT FOUND
> > 4854 0.01366514 acad.exe:1376 IRP_MJ_CREATE
> > R:\4108\004.dwg\:Docf_DocumentSummaryInformation:$DATA FILE NOT FOUND
> > 4855 0.01357519 acad.exe:1376 IRP_MJ_CREATE
> > Options: Open
> > 4856 0.01442865 acad.exe:1376 IRP_MJ_CREATE
Attributes:
> N
> > Options: Open
> > 4857 0.01330728 acad.exe:1376 IRP_MJ_CREATE
> > Options: Open
> > 4858 0.01383025 acad.exe:1376 IRP_MJ_CREATE
Attributes:
> N
> > Options: Open
> > 4859 0.01350730 acad.exe:1376 IRP_MJ_CREATE
> > R:\4108\004.dwg\:SebiesnrMkudrfcoIaamtykdDa:$DATA FILE NOT FOUND
> > 4860 0.01380315 acad.exe:1376 IRP_MJ_CREATE
> > R:\4108\004.dwg\:Docf_SebiesnrMkudrfcoIaamtykdDa:$DATA FILE NOT FOUND
> > 4861 0.00008632 acad.exe:1376 IRP_MJ_CLEANUP R:\4108\004.dwg SUCCESS
> > 4862 0.00023020 acad.exe:1376 IRP_MJ_CREATE R:\4108\ SUCCESS Attributes:
> Any
> > 4863 0.01234878 acad.exe:1376 IRP_MJ_DIRECTORY_CONTROL R:\4108\ SUCCESS
> > 4864 0.00003604 acad.exe:1376 IRP_MJ_CLEANUP R:\4108\ SUCCESS
> > 4865 0.00020058 acad.exe:1376 IRP_MJ_CLOSE R:\4108\ SUCCESS
> > 4866 0.00023997 acad.exe:1376 IRP_MJ_CREATE R:\4108\ SUCCESS Attributes:
> Any
> > 4867 0.01212696 acad.exe:1376 IRP_MJ_DIRECTORY_CONTROL R:\4108\ SUCCESS
> > 4868 0.00003492 acad.exe:1376 IRP_MJ_CLEANUP R:\4108\ SUCCESS
> > 4869 0.00028523 acad.exe:1376 IRP_MJ_CLOSE R:\4108\ SUCCESS
freeware
> at
