Hi folks,
I've just purchased and installed Sketchbook Pro 7 (64-bit version) on my Pc (Win 7 Ultimate 64-bit, Core i5, 16GB RAM) and I keep getting the following error every time I launch the program (see image). If I click 'Try Again', or 'Continue', Sketchbook then runs without any apparent problems. The message is extremely irritating though and doesn't inspire confidence that everything's running smoothly 'under the hood' - has anyone else encountered this issue and managed to fix it?
Thanks.
UPDATE: I've uninstalled SB Pro 7, removed all Autodesk registry entries, rebooted and reinstalled the software via the direct browser download version and so far all appears to be working fine now.
