Hi All,
I have just started to look at the installation requirements for our School and wondered if the Single Server Licence Model will work across subnets?.
I have looked around the forums and there are indications that it can but nothing difinitive.
We have a 2 campus, single domain, multiple subnet MS2012 environment where the management servers are on a different subnet to the PC's we are looking to use.
Many Thanks in advance.
Carlos
Solved by TravisNave. Go to Solution.
Yes it will work and I can recommend it due to it being the easiest way to get set up and running. I run a single license manager that serves dozens of our other offices nationwide over our WAN. Each office is on its own subnet. I can assure you, in writing, that it does indeed work for your needs. So long as each office can see the server access at your home base, you will have no issues. Or at least no issues that can't be easily addressed.
