Solved by camilo.lemos. Go to Solution.
Hi carl_vr_stud, welcome to the Autodesk Community!
I've tested this and I was able to reproduce this behavior. I'll clarify with the product team and will get back to you as soon as I have an answer.
Thanks for bringing this up!
Thanks for the quick response and having a look at this.
Kind Regards
Carl van Rooyen
I've just spoken to the Simulation produc team about this:
The installer will work on both the 32 and 64-bit versions, it was simply named incorrectly. You can go ahead and install this on your 64-bit system and you should run into any issues.
The product team are looking into renaming the file.
Please accept as solution if my post fully resolves your issue, or reply with additional details if the problem persists.
