Installation & Licensing
New Member
chaitanya.yellapu
Message 11 of 16 (860 Views)
Re: Silent Uninstall of AutoCAD 2011 via SCCM
02-21-2013 11:10 AM in reply to: tmpamlrs
After installation of autodesk product , we will get the registry with uninstal string of autodesk silent parameter.
"""C:\Program Files\Autodesk\Inventor 2012\Setup\Setup.exe"" /q /P {7F4DD591-1664-0409-0000-7107D70F3DB4} /R INVENTOR /LANG en-US /Wait", 1, True
Example for Autocad inventor.
chaitu
Member
jlewis808
Message 12 of 16 (686 Views)
07-29-2013 12:53 PM in reply to: tmpamlrs
Has anyone successfully remotely uninstalled Autocad 2011? I am using EMCO remote installer 4 and have not been able to get it to work with any parameter.
I have used
/x/q
msiexec /x {5783F2D7-9005-0409-0102-0060B0CE6BBA} /q
Setup.exe /x {5783F2D7-9005-0409-0102-0060B0CE6BBA}
Setup.exe /x {5783F2D7-9005-0409-0102-0060B0CE6BBA} /q
and many more combinations without success.
Also, does anyone have a recommendation for deploying Autocad 2014 via EMCO, AD, SCCM, etc????
*Expert Elite*
GTVic
Message 13 of 16 (683 Views)
07-29-2013 01:01 PM in reply to: jlewis808
Do you have the right coding, your screen capture shows Mechanical but that is not mentioned in your post?
msiexec /x {B96F1390-23DD-4002-B183-EF0560D784E9} /qb! /Passive /l*v ACAD2011WSPlugIn_UI.log
msiexec /x {42E572CC-6D4C-4A3E-B937-7594D36B2B44} /qb! /Passive /l*v ACAD2011SubAdvPack_UI.log
msiexec /x {711883AE-ED83-4327-9DFA-053F969344CA} /qb! /Passive /l*v ACAD2011CivilOE_Uninstall.log
msiexec /x {6EFD3469-9001-4A85-B52F-2B6C27E946BE} /qb! /Passive /l*v ACAD2011RasterDesignOE_UI.log
msiexec /x {5783F2D7-9001-0409-0002-0060B0CE6BBA} /qb! /Passive /l*v ACAD2011_R18.1.208.0_UI.log
msiexec /x {5783F2D7-9001-0409-1002-0060B0CE6BBA} /qb! /Passive /l*v ACAD2011LanguagePack_UI.log
msiexec /x {CD1E078C-A6B9-47DA-B035-6365C85C7832} /qb! /Passive /l*v ACAD2011BaseImage_UI.log
msiexec /x {9DEABCB6-B759-4D52-92F8-51B34A2B4D40} /qb! /Passive /l*v ACAD2011MaterialLibrary_UI.log
msiexec /x {951B0F30-9F1A-4BF6-B3DA-99EB0E917B1C} /qb! /Passive /l*v FARO_LSSDK_UI.log
Member
jlewis808
Message 14 of 16 (675 Views)
07-29-2013 01:13 PM in reply to: GTVic
I suppose not. How would I uninstall it?
The GUID that I have is the 5783F2D7-9005-0409-0102-0060B0CE6BBA.
Thanks for the quick response by the way!
*Expert Elite*
GTVic
Message 15 of 16 (662 Views)
07-29-2013 03:12 PM in reply to: jlewis808
My post shows the commandline that works. You can get the correct GUIDs from your computer registry.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\
If you use the command line format the log file will give you additional details about what is wrong
Member
jlewis808
Message 16 of 16 (652 Views)
07-30-2013 08:50 AM in reply to: GTVic
I had the correct GUID from the registry.
I ended up trying PSExec.
I already had PSEXEC dowloaded.
Went to Start > Run> typed: Runas /user:administrator@DOMAINNAME cmd
I used this command:
C:\PSTools>PSEXEC \\COMPUTERNAME msiexec /x {5783F2D7-9005-0409-0102-0060B0CE6BBA} /qb! /Passive /l*v ACAD2011Mechanical_Uninstall.log
This was the response (took about 3 - 5 minutes ):
msiexec exited on CP188 with error code 0.
code 0 means all good.
Checked remote machine and AutoCad 2011 Mechanical was uninstalled.
What I didn't realize is that EMCO goes out to the registry and looks for the Uninstall String of the Product.
You will see the Command it is sending in the attached screenshots.
It was trying to run:
C:\Program Files\Autodesk\ACADM 2011\Setup\Setup.exe /P {5783F2D7-9005-0409-0102-0060B0CE6BBA} /M/ACM /lang en-US
THEN ATTACHING MY COMMAND OF
TO THE END OF THE ENTIRE COMMAND
Now I just have to figure out how the tell EMCO Remote Installer to use this command instead of the whole thing.
Thanks again.
Announcements
Need installation help?
