How i can silent install SP1.1, what kind of keya i have to use?
whan i tried use command
AutoCAD_2013_SP1.1_64bit.exe /q
nothing happend
thank you for your answers
Look for a newly created log file in %TEMP% and see if it has any clues.
http://unattended.sourceforge.net/installers.php has some good information on how to run various types of silent installations, but i've tested the obvious ones with no success...
First convert the EXE file to an MSP with the following command:
AutoCAD_2013_SP1.1_64bit.exe /e ./AutoCAD_2013_SP1.1_64bit.msp
Then you can deploy the MSP silently with the following command:
msiexec.exe /p "AutoCAD_2013_SP1.1_64bit.msp" /qn /norestart /log output.log
This should work with any of the EXE update releases that Autodesk provides.
