Installation & Licensing
showing error while installing autocad 2012.
4 REPLIES 4
pareshmangal007
504 Views, 4 Replies
Sir, while i am instaliing autocad 2012,it shows a error message many times..I have aready installing Microsoft  c++ 2010 *86 from it site..but after that i am having same problem..
    I send u a snapshot of problem statement.
Thanks..
4 REPLIES 4
in reply to: pareshmangal007
I am no expert but I think you need to install the DirectX runtime installer. That appears to be what is making it fail.
pareshmangal007
I alredy hve installed Direcy X recommended by u..but it also doesn't work.
How about trying to load .net framework 4.0 It has been a little while since I have loaded 2012 but I seem to remember there needing to be a couple other things loaded before I could install 2012.
Copy the installation media to your hard drive.  Install with local admin rights.  DO NOT add a service pack during the install.  Make sure there is not already an AutoCAD 2012 folder under Program Files.  Disable your anti-virus and make sure UAC is off.  See my 1603 link for more information.
Autodesk Forums:
Administrator Productivity
