Installation & Licensing
Showcase 2014 fails to open
5 REPLIES 5
1677 Views, 5 Replies
XPost from the Showcase forums, but I see it doesn't get as much traffic as this does:
I just installed Showcase 64 bit on to Win 7 - 64 Pro and I see the following:
Error Report - Required Value Missing
An Autodesk product failed to send the required value for SERIALNUM
The error report sent to Autodesk may be incomplete.
And the software won't install. I input the Serial Number and it was accepted during installation.
5 REPLIES 5
philip.s
HI Eric,
Can you please check the Windows Features and make sure that .net framework is enabled. If so what version is installed?
Start button -> Control Panel -> Programs -> Turn Windows features on or off
in reply to: philip.s
I'm a .NET developer, I have all versions of .NET installed
david.lau
in reply to: david.lau
Yes, David Lau's solution worked. Thank you.
(hmm, someone accepted this as solution before I verified it... oh well)
derek.leungHMH92
Hello All,
I apologize for revisiting this issue.  The link under the "up and ready" page provided by David Lau seems to be broken, so I don't know which patch you guys used.  I am getting this error message for Nastran In-Cad 2017 and I can't find a solution for it in the forums.
Any help is appreciated,
Derek
Administrator Productivity
