After installing the Product Auotdesk AUTOCAD LT 2015 in Admin Login, the
shorcut throws error at its first launch in User Login.
The software was installed with elevated (admin) privileges. Does this error mean that everyone who
wants to install and use AutoCAD requires to be a local admin on the system???
It looks like you do not have enough permissions on the user account to allow the secondary installer to finish. Each user account, when they start the software for the first time, needs to build secondary profile information. Your users cannot. I would loosen the restrictions on the user accounts and retry.
You can also try to add user permissions to the AutoCAD folders.
C:\Users\All Users\Autodesk
C:\Users\<the current user>\AppData\Local\Autodesk
C:\Users\<the current user>\AppData\Roaming\Autodesk
C:\Program Files\Common Files\Autodesk Shared
C:\Program Files\Autodesk
C:\ProgramData\FLEXnet
C:\ProgramData\Autodesk
Thank you for taking part in our community!
