In Acad 2015 LT, I have dimensioned model space objects, while in paperspace.
If/when I save the file, leave it open to do something else, and then return to the still open file, some, but not all of the dimensions have stretched themselves way off the page. this has also been happening when if I save, close and re-open the file.
This has occurred in more than one drawing.
Does anyone know how to stop this from happening?
Thank you
Solved by pendean. Go to Solution.
ps. I should note that file used to have a lot of xrefs attached to it. Some of the items I had been dimensioning, were located on those xrefs. I don't know if that will make a difference. I have inserted the linework, that had been xref/attached originally.
K
Thank you for your help and input. I will try alt ways of dimensioning. I will also try to reassociate the dims.
Strange though, I purged that dwg a couple times before I sent. Maybe I should have purged, closed, reopened and purged again.
k
