Installation & Licensing
Setting up Borrow time limit
2 REPLIES 2
605 Views, 2 Replies
I have one user that I Want to borrow the license for an extended period.
Do I set this thru the manager or does he just pick the return time when he
checks it out? I thought there was a 30-day limit set somewhere.
Todd W
LDD 2009, Civil 3D
XP Pro SP2a
4 G Ram
2 REPLIES 2
Take a look at:
http://usa.autodesk.com/getdoc/id=TS64997
R.K. McSwain
http://rkmcswain.blogspot.com
TravisNave
The limit used to be 30-days back a few versions. But the latest borrow time is 6 months. You cannot extend the maximum borrow time for a product. You can only decrease the time with an adskflex.opt options file.
Therefore, if you are running AutoCAD 2004, then your limit is still 30-days. But 2009 would be 6 months.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
