Installation & Licensing
Setting up a sam report log.
1 REPLY 1
donovan_cox
336 Views, 1 Reply
I'm trying to set up sam report, i think i'm following the directions. What i'm having problems with is getting the license deamon to generate a report.rl file for me. I've set up an options file containing a string for where to create the log, and it includes a license timeout. When i check my server logs after starting i get an error, and no logs generated. Did i screw up somewhere in my syntax?
Options file text
REPORTLOG [+]"h:\tech\Sam_Report_Logs\report.rl"
TIMEOUTALL 600
when i check my server log i get the following
15:29:55 (adskflex) Rereading options file...
15:29:55 (adskflex) ALL FEATURES: INACTIVITY TIMEOUT set to 600 seconds
15:29:55 (adskflex) Reread REPORTLOG switched to [+] "H:\tech\Sam_Report_Logs\report.rl
15:29:55 (adskflex) Can't open report log file [+] "H:\tech\Sam_Report_Logs\report.rl: Invalid argument, 253
15:29:55 (adskflex) ...Finished rereading
1 REPLY 1
in reply to: donovan_cox
well just so ya'll know I know why it didn't work. I had a case of bad syntax. the brackets around the plus sign didn't belong. I also seemed to have needed 2 spaces between reportlog and the + REPORTLOG [+]"h:\tech\Sam_Report_Logs\report.rl" "donovanc" wrote in message news:4024224.1092257427624.JavaMail.jive@jiveforum1.autodesk.com... > I'm trying to set up sam report, i think i'm following the directions. What i'm having problems with is getting the license deamon to generate a report.rl file for me. I've set up an options file containing a string for where to create the log, and it includes a license timeout. When i check my server logs after starting i get an error, and no logs generated. Did i screw up somewhere in my syntax? > > Options file text > REPORTLOG [+]"h:\tech\Sam_Report_Logs\report.rl" > > TIMEOUTALL 600 > > > when i check my server log i get the following > > 15:29:55 (adskflex) Rereading options file... > > 15:29:55 (adskflex) ALL FEATURES: INACTIVITY TIMEOUT set to 600 seconds > > 15:29:55 (adskflex) Reread REPORTLOG switched to [+] "H:\tech\Sam_Report_Logs\report.rl > > 15:29:55 (adskflex) Can't open report log file [+] "H:\tech\Sam_Report_Logs\report.rl: Invalid argument, 253 > > 15:29:55 (adskflex) ...Finished rereading
Administrator Productivity
