I got the following error code when I tried to download the service pack 1: AutoCAD Error Code 1603. Anyone have any idea what to do to fix this? I don't have install disks since I downloaded an educational version from Autodesk.
This article might help:
http://usa.autodesk.com/getdoc/id=TS22132908
Your user just needs to have local administrative rights. You can verify this in your Control Panel.
Otherwise, if you want to actually use the built-in administrator account, do this:
1. Launch the Command Prompt as Administrator by right-clicking it and run as Administrator
2. Type this and hit enter:
net user administrator /active:yes
3. Log back in as the Administrator. Install.
Good Luck!
I ran ACAD 2014 as administratior but still got the same error message. 😞 Frustrating.
