Installation & Licensing
Service Pack 1 Install Errors for ACAD 2014
4 REPLIES 4
kmfinchpdx
1742 Views, 4 Replies
I got the following error code when I tried to download the service pack 1: AutoCAD Error Code 1603. Anyone have any idea what to do to fix this? I don't have install disks since I downloaded an educational version from Autodesk.
4 REPLIES 4
bryce.thelin
in reply to: kmfinchpdx
This article might help:
http://usa.autodesk.com/getdoc/id=TS22132908
Bryce Thelin
AutoCAD Product Support
Tags (1)
kmfinchpdx
Thanks. How do I login as an administrator in Windows 8?
TravisNave
Your user just needs to have local administrative rights.  You can verify this in your Control Panel.
Otherwise, if you want to actually use the built-in administrator account, do this:
1.  Launch the Command Prompt as Administrator by right-clicking it and run as Administrator
2.  Type this and hit enter:
net user administrator /active:yes
3.  Log back in as the Administrator.  Install.
Good Luck!
Autodesk Forums:
kmfinchpdx
in reply to: TravisNave
I ran ACAD 2014 as administratior but still got the same error message. 😞 Frustrating.
Administrator Productivity
