I've been trying to download and install service pack 1 and 2 for my revit 2014.
I have a student license, and the reason i would like to installe packs 1 and 2 is an error when i'm trying to render in cloud.
Seems the packs cannot find my revit file.
What to do?
Based on your description it isn't clear what problem you've encountered but it sounds like you might be trying to install the wrong version of the service pack. It is important to remember that there are several versions of Revit, including Revit, Revit Architecture, Revit LT, Revit MEP and Revit Structure, and there are specific service packs for each.
If you have Revit 2014, you should download the appropriate service pack (32 or 64-bit) from this page:
http://knowledge.autodesk.com/support/building-design-suite/downloads/caas/downloads/content/revit-2...
If you have Revit Architecture 2014, you'll need to download the appropriate service pack (32 or 64-bit) from this page:
By the way, Revit service packs are cumulative (SP2 includes all of the SP1 fixes) so you don't have to install SP1 and SP2 individually. If this information doesn't help you to get the service pack installed, please provide the exact error message you encounter and we can investigate further.
Tony Michniewicz
Autodesk Revit QA
