Have you upgraded to the license server exe files that comes with 2009 on
both 1 and 2?
Jimmy Bergmark
JTB World - CAD software, development and consulting
Owner/Developer
http://www.jtbworld.com
http://blog.jtbworld.com
JTB FlexReport (FLEXnet / FLEXlm license report tool) -
www.jtbworld.com/jtbflexreport
AutoCAD 2009
http://www.jtbworld.com/autocad2009.htm
"AWood" skrev i meddelandet news:5913433@discussion.autodesk.com...
> Hi All,
> Here's a strange one.
> I have a 10 laptop mobile lab with a distributed server model.
> Lab01 and Lab02 are the license managers.
> Very basic deployment - all machines XP Pro SP2 with Civil3D 2008 and
> Raster 2008 as network deployments. Peer2Peer network. Nothing fancy
> and.....
> The 08 products launch fine and the LM recognizes the license on all 10
> machines...
> Keep in mind Lab02 (the 2nd LM) has not been turned on for the last
> week...this will make sense later...
> I was doing a network deployment of Civil3D 2009 to Lab01 (the main
> license server), Admin Image installed fine and I installed the software
> on Lab01, the LM recognized all of the licenses, but when launching C3D09
> on Lab01 I get a "Specify License Server" dialog.
> I type in the server name Lab01 (incidently the same system the LM and
> C3D09 are on) and I get a <<"Server "Lab01" did not respond within 5
> seconds, the server may not exist, or communications are not possible at
> this time">> dialog...
> I went through a number of troubleshooting...Ethernet address in system
> and LIC fil match (the 2008 products still launch), the
> ADSKFLEX....variable is set correctly ( @Lab01; @Lab02 ) (BTW the 08
> products still launch) even LICPATH.LIC is good....Registry entries seem
> ok....
> 2009 will still not launch (see 5 second error above)....
> So....................Here's the weird part
> (Keep in mind Lab02, the second LM, has not been turned on in a week)
> I went and booted up Lab02 to see if I could use that as the LM and
> Network deployment system for the C3D2009.
> I checked the LMTOOLS => Server Diagnostic and...........It actually shows
> both 2008 and 2009 licenses - This machine has not been booted during this
> whole procedure.
> How could Lab02 be seeing the licenses? The license file for Lab02 only
> has the 2008 products (why does Lab02 see 2009 licenses that are not even
> in it's own license file)?...
> I tried to set Lab01 to see the Lab02 LM but same error.
> (another BTW - ping between system are fine - I can see shared folders,
> network folders, tracert, ipconfig looks great, etc...)
> Plus, I still can't get 2009 to launch even considering both LMs see all
> of the licenses...
> Any ideas, suggestions???
> I have a 2009 New Features Workshop to do with the mobile lab on Friday
> (no pressure)
> Thanks in advance for everybody's time...
> Cheers,
> AWood
