Installation & Licensing
jonmhines1
3389 Views, 4 Replies
Serial Number
I somehow lost all relations to a bunch of files that were needed to create models and drawings so I had to reinstall Autodesk Product Design Suite 2013 Premium on my computer.  After completing install and trying to register I got this error code.  The serial number you entered is not valid for the product you are trying to activate. Try again. (Error 123).  Without being able to get into Inventor or any of the other programs in Design Suite I can't get any of the work done I am supposed to!!  Please help!
Jon
Tags (2)
4 REPLIES 4
TravisNave
in reply to: jonmhines1
This is usually typical of products on Subscription.  Start here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-S...
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
RA57027665
can u send me the updated serial and product key numbers,
because the ones i was trying to activate my autocad 2013 with it tells me they are not valid
ronf
in reply to: TravisNave
I need a serial number for my new license if AutoCad r2-15 for mac. 2016 has not released a mac version yet. I sent a request sometime ago but it has not yet arrived and I am getting 0 value from my new vey expensive license.
matthew.d
in reply to: ronf
Hi @ronf,
There are multiple licenses available in your Autodesk Account. Could you provide an order number for your Mac purchase?
Matt DiMichele
Autodesk Product Blogs | @ADSKCommunity Twitter
Likes are greatly appreciated. Everyone enjoys a thumbs up!
Please Accept As Solution if this resolves your issue, to help others benefit and locate it.
Administrator Productivity
