Installation & Licensing
New Member
1 Kudo
Post 1 of 5
Serial number and Product key Problems
344 Views, 4 Replies
10-12-2012 05:25 PM
I keep getting the alert "The Serial Number or Product Key don't Match. Valid format for serial number is (XXX-XXXXXXXX)"  and i know that i am putting in right every time.  What should I do?
New Member
0 Kudos
Post 2 of 5
Re: Serial number and Product key Problems
10-13-2012 02:17 PM in reply to: Akay87
the same thing is happening to me and i KNOW that i am putting it in correctly. help!
20 Kudos
Post 3 of 5
10-14-2012 06:09 PM in reply to: Akay87
For activation issue, please contact our Registration and Activation Team for assistance. Please make sure to provide the following information:
Serial Number:
Product Name:
Product Version:
Request Code:
For steps on to retrieve your request code, please click here.
Have a nice day!
Best Regards,
Arlin Bibat
Product Support
30 Kudos
Post 4 of 5
10-14-2012 07:19 PM in reply to: Akay87
Hi, Akay87
Welcome to Autodesk discussion group, we will help you with your problem.
As what you mentioned the SN and Product Key not matched, does this happens during your installation?  If this is the case, then I have some suggestions for you:
1  Please make sure to close any input method when you enter the SN and PK.
2  Please make sure to use the correct SN and PK, you can refer to this solution to find your SN and PK.
If above not solve your issue, Could you please send your error image for understanding your problem?
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Emily Xu
New Member
1 Kudo
Post 5 of 5
10-15-2012 09:37 AM in reply to: smithhe2
i just find out what to do...... download the 30day trial and when it is done and you open auto cad one of the screen on the bottom u can put in the serial number and the product key that's how i got it to work......
