I keep getting the alert "The Serial Number or Product Key don't Match. Valid format for serial number is (XXX-XXXXXXXX)" and i know that i am putting in right every time. What should I do?
For activation issue, please contact our Registration and Activation Team for assistance. Please make sure to provide the following information:
Serial Number:
Product Name:
Product Version:
Request Code:
For steps on to retrieve your request code, please click here.
Have a nice day!
Best Regards,
Hi, Akay87
Welcome to Autodesk discussion group, we will help you with your problem.
As what you mentioned the SN and Product Key not matched, does this happens during your installation? If this is the case, then I have some suggestions for you:
1 Please make sure to close any input method when you enter the SN and PK.
2 Please make sure to use the correct SN and PK, you can refer to this solution to find your SN and PK.
If above not solve your issue, Could you please send your error image for understanding your problem?
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
