sir,
I am having autocad2010 64bit version and downloaded from internet and after downloading i had seen that it was a trial version,now what should i do to make it full version.
this was the information given
MID: ACAD_2010_64bit_SWL_EN_D055_EXE1_MLD
Product Name: AutoCAD 2010
Platform: Windows XP/Vista
Media: ESD
Part Number: 001B1-05ZD01-P501E
AutoCAD (s) is a registered trademark of Autodesk, Inc.
Copyright 1982-2009 by Autodesk, Inc. All rights reserved.
please send me the serial key or rack to make it full version.
Solved by simona.golisciano. Go to Solution.
Either buy it from a authorized reseller or directly from Autodesk. Current version is 2012
http://store.autodesk.com/store/adskus/DisplayHomePage
I assume since this is 2010 you are a student.
All Autodesk software initially installs in 30-day trial mode to give you several weeks to make sure it is running correctly as you can only activate twice.
Did you watch the videos on the student website on how to download, extract, install and activate?
If so, what part did you not understand?
1.Start Program
2. Click Activate on the Trial/Activate splash screen and follow the on-screen instructions to activate your FREE 3-yr student license.
In any case, you are posting your question in the wrong forum - see http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
You should also be aware that AutoCAD is not Autodesk Inventor (or AutoCAD Inventor).
i cannot activate the autocad by using the serial number 666-69696969 please help me to activate my autocad 2010
@raviteja4 wrote:sir,
Media: ESD
Part Number: 001B1-05ZD01-P501EAutoCAD (s) is a registered trademark of Autodesk, Inc.
Copyright 1982-2009 by Autodesk, Inc. All rights reserved.please send me the serial key or rack to make it full version.
Where did you purchase the software. (please provide specific information)
Welcome to the community
Your reply is blank... Do you have an actual issue?
Mark Lancaster
& Autodesk Services MarketPlace Provider
sir,i have already a trial version of autocad 2010 with serial number 666-69696969 and request code of X9D2 C1X5 8LKT L7UP NUX9 XLX2 Z7QF UO32. Please send me the activation code. Thank you...
First of all.. Don't share personal information here such as your serial #. This is world wide public user forum. Granted this is a legacy version and it really doesn't matter but don't share that type of information.
In addition just because you have a serial # and request code doesn't mean your software can be activated. Its based on the history of the serial # and its still valid. May I ask why you need to activate a legacy, unsupported, retired Autodesk Product?
Mark Lancaster
Hi @Heryoma,
Welcome to the Community!
The 2012 release of AutoCAD would require Microsoft .NET Framework 4.0. See below online solutions:
Microsoft .NET 4.0 pre-requisite for Autodesk 2012 product installations
More recent versions of AutoCAD won't work with NET 4.0. Please refer to the System Requirements to check which Microsoft .NET is required.
i use autocad 2010 serial no xxx-xxxxxxxx and code 0000 but not activated, now cant open aotocad
want serial no and cade for activate
@titlikamal143 Autodesk ended automatic reauthorizing of many older software recently, read all about it here
https://forums.autodesk.com/t5/previous-version-support/reminder-no-change-to-previous-version-suppo...
https://knowledge.autodesk.com/customer-service/account-management/users-software/previous-versions/...
But... you might be able open a ticket with the Licensing support and confirm your options for sure here https://knowledge.autodesk.com/contact-support/installation-activation
Or find and contact a reseller in your region for assistance https://www.autodesk.com/partners/locate-a-reseller
