I have an installation of Inventor LT on my PC, on a Windows XP partition. I have an installation of Windows 7 on a second partition of the same PC. Can I install Inventor LT on this partition also?
The physical act of installing should not be an issue, but activating on all those systems will probably be an issue. You can only activate once for as many machines as you have seats. Each partition is basically a different system. You can try, but I am guessing you will run out of activations eventually.
Thank you for taking part in our community!
