I am trying to install revit to a second drive in my computer (E:\ drive). This is because my boot drive (C:\) is a small capactiy SSD drive to improve my boot and other program speeds and it does not have the capacity required. I tried to install onto my secondary HDD that has 350+ GB of free space and am recieving errors. The download file was also to the drive and I changed the install path to my secondary drive.
Any idea why this isn't working out for me?
Post your installation log located in yoru %TEMP% file. The reason can probably be determined fairly easily. It's likely a prerequisite installation issue.
2012/2/6:12:19:57 Hahano HAHANO-PC === Setup started on HAHANO-PC by Hahano ===
2012/2/6:12:19:57 Hahano HAHANO-PC Launch
2012/2/6:12:20:15 Hahano HAHANO-PC === Setup ended ===
2012/2/6:12:35:07 Hahano HAHANO-PC === Setup started on HAHANO-PC by Hahano ===
2012/2/6:12:35:07 Hahano HAHANO-PC Launch
2012/2/6:12:35:07 Hahano HAHANO-PC An instance of setup is already running. Only one instance of setup can run at a time.2012/2/6:12:35:09 Hahano HAHANO-PC === Setup ended ===
2012/2/6:12:20:15 Hahano HAHANO-PC PageOpen LaunchDialog
2012/2/6:12:27:34 Hahano HAHANO-PC PageOpen LicenseDialog
2012/2/6:12:33:19 Hahano HAHANO-PC PageOpen ProductInfoDialog
2012/2/6:12:33:43 Hahano HAHANO-PC PageOpen ProductSelectionDialog2
2012/2/6:12:37:31 Hahano HAHANO-PC PageOpen ProductInfoDialog
2012/2/6:12:37:34 Hahano HAHANO-PC PageOpen ProductSelectionDialog2
2012/2/6:12:41:03 Hahano HAHANO-PC PageOpen FullProgressDialog
2012/2/6:12:41:03 Hahano HAHANO-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): E:\AutoDesk\Revit\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Hahano\AppData\Local\Temp\vcredist_x86_2005.log"" "
2012/2/6:12:41:07 Hahano HAHANO-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2012/2/6:12:41:07 Hahano HAHANO-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): E:\AutoDesk\Revit\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2012/2/6:12:41:11 Hahano HAHANO-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2012/2/6:12:41:11 Hahano HAHANO-PC Installing Microsoft Visual C++ 2010 Redistributable (x86): E:\AutoDesk\Revit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\Hahano\AppData\Local\Temp\vcredist_x86_2010.log
2012/2/6:12:41:13 Hahano HAHANO-PC Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
2012/2/6:12:41:13 Hahano HAHANO-PC Rollback Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2012/2/6:12:41:13 Hahano HAHANO-PC Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
2012/2/6:12:41:29 Hahano HAHANO-PC === Setup started on HAHANO-PC by Hahano ===
2012/2/6:12:41:29 Hahano HAHANO-PC Launch
2012/2/6:12:41:34 Hahano HAHANO-PC === Setup ended ===
2012/2/6:12:41:34 Hahano HAHANO-PC PageOpen LaunchDialog
2012/2/6:12:45:39 Hahano HAHANO-PC PageOpen LicenseDialog
2012/2/6:12:50:03 Hahano HAHANO-PC PageOpen ProductInfoDialog
2012/2/6:12:50:25 Hahano HAHANO-PC PageOpen ProductSelectionDialog2
2012/2/6:12:52:49 Hahano HAHANO-PC PageOpen FullProgressDialog
2012/2/6:12:52:49 Hahano HAHANO-PC Installing Microsoft Visual C++ 2010 Redistributable (x86): E:\AutoDesk\Revit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\Hahano\AppData\Local\Temp\vcredist_x86_2010.log
2012/2/6:12:52:51 Hahano HAHANO-PC Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
2012/2/6:12:52:51 Hahano HAHANO-PC PageOpen InstallCompleteDialog
2012/2/6:12:54:16 Hahano HAHANO-PC === Setup ended ===
That's what I figured.
You will want to go into your Control Panel and remove any Visual C++ 2010 you have installed. Then let the Autodesk installer reinstall it. That usually clears up this issue.
I am having this trouble as well. I removed the C++, but it continues to give the same error. It brings up a dialogue box that shows the available drives, and I select my E: drive, but it keeps giving the same error even though there is much more than enough space for the installation.
