Installation & Licensing
260 Views, 3 Replies
Saving issues
I am working on Revit 2014 and for some reason it will not allow me to save my work anymore.  Throughout the process of creating a project I have been able to save until today.  I know that my license is still valid, as I just installed the software last month and have over 1000 days of service.  The same error message appears:
Autodesk Revit 2014
Build: 20141024_2115(x64)
License unavailable.  Autodesk Revit 2014 is in viewer mode.
Viewer mode allows all runctionality of Revit, except the following: save or save as in all cases; exporting or publishing modified projects; exporting or publishing any projects to a format containing model data that can be modified; or printing projects after changes are made.
If anyone knows how to solve this issue, please let me know immediately.
Thank you,
BJ Patel
3 REPLIES 3
asburyj
Hi BJ and welcome to the forum.
Is this a network license version of Revit? If so, have you confirmed the network license server is still up and has Revit licenses available?
Jeffry Asbury
in reply to: asburyj
Yes the license is still up, not sure why this is happening, but I tried to save the file again under a different name, and it saved this time.  Not sure why this would be happening, but is there anything I can do to prevent this from happening again?  I did have to start over fromt the last time I saved, which cost me almost two hours of work.
asburyj
Can you upload a copy of the debug log from your server? This should tell us why the license was unavailable and you had to go to viewer mode.
Jeffry Asbury
Administrator Productivity
