I'm just getting LT 2014 up and running. When plotting I put a check mark in SAVE CHANGES TO LAYOUT.
In LT 2008 once I did that it remained permanently. In LT 2014 the check mark is gone when I go to do another plot out. I can't resave the template with the check mark there because it goes away as soon as I do the plot.
Is there something in the OPTIONS, PLOT AND PUBLISH tab I need to change? Or is the setting elsewhere?
BH
Solved by pendean. Go to Solution.
