Hi Collin,
the "FLEXlm error: -53,234" which means that you didn't navigate your SAM
Report to the report log file which should be generated by FLEXlm if you
have set it in options file.
Efim
"molokaiboy" wrote in message
news:17551686.1091644755472.JavaMail.jive@jiveforum2.autodesk.com...
> I am trying to do the same thing and get this error msg:
> For further information, refer to the FLEXlm End User Manual,
> available at "www.globetrotter.com". Continuing...
> Unable to generate report: Error: No report logs to process
> I am running Samreport v3.2
> Can you advise.
> Thanks,
> Collin
