Installation & Licensing
Running Flexlm functions from a command line.
2 REPLIES 2
Jroper
1269 Views, 2 Replies
Normally, when I alter the .opt file, etc. for Autodesk licenses, I remote into the license server and run the LMTOOLS app to make changes.  I know that Flexlm functions (lmreread, lmgrd, lmstat, etc.) can be used to administrate the license server through a command line.  Can someone point me to a guide on these Flexlm functions and the safe way to execute them?
2 REPLIES 2
TravisNave
in reply to: Jroper
Absolutely!  The official FLEXLM guide can be downloaded directly here:
http://www.globes.com/support/utilities/fnp_LicAdmin_11_12_1.pdf
You can then run all the lmutil.exe commands using that guide.  They work well, btw.
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Jroper
in reply to: TravisNave
Thanks, just what I needed.
Administrator Productivity
