Installed on a system that already has Autocad 2010 LT. PC is Windows 7 Pro 32-bit. License is on a server. There are two other computers who check out the license just fine and one being RSA Pro 2010. When the RSA Pro 2010 license is checked out we get an error message. Perfect, it talks to the server. When the license is free, you go to open RSA Pro 2010 and it immediately closes. In the logs it just says that user checked out the license and then right away checked it back in.
I installed it as a standalone by mistake the first time around and the program launches. So I know this has got to do something with the network license mode.
Any insight is appreciated.
Solved by TravisNave. Go to Solution.
Check this KB about the CascadeInfo.cas file:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240617&id=13894457&siteID=123112
That's what I tried just before leaving work last night and the user came back stating that it worked. As simple as renaming that file and have it regenerated worked for me.
