Installation & Licensing
New Member
0 Kudos
Post 1 of 6
Roaming Profiles and preventing "First Run" installation
731 Views, 5 Replies
02-18-2014 09:28 AM
I'm using roaming profiles for Autocad 2014 (network deployment) in a computer lab.  Things seem to be working but every time Autocad is launched on the computers it has to go through the very long "first run" installation.  I have copied the Autodesk folder from %userprofile%\AppData\Local up to the roaming profile on the network but I'm still having this happen.  Are there other files/folders that need to be copied to the roaming profile to get past this "first run" operation?
Yes, unfortunately roaming profiles are not compatible with AutoCAD.
Product Support
99 Kudos
Post 2 of 6
Re: Roaming Profiles and preventing "First Run" installation
02-18-2014 01:58 PM in reply to: jd239
AutoCAD writes into appdata local and appdata roaming and also access locations in the user profile folders like my pictures.You can find some details on this in the article linked below.
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Seconda...
Jeffry Asbury
New Member
0 Kudos
Post 3 of 6
02-19-2014 04:03 AM in reply to: asburyj
"To resolve this issue, you need to disable the deletion of locally cached profiles for users who will be running the application."
So the Autodesk solution to the problem of roaming profiles is to not use roaming profiles?  Great...
Product Support
99 Kudos
Post 4 of 6
02-19-2014 09:37 AM in reply to: jd239
Jeffry Asbury
New Member
0 Kudos
Post 5 of 6
08-27-2014 10:06 AM in reply to: asburyj
We used roaming profiles last year with AutoCAD and it worked beautifully. We installed the new education software this year, and now it's broken. TWO DAYS before school starts. We have no other option but to use roaming profiles in our environment since the students go from lab to lab and they need their profiles to follow them.
New Member
0 Kudos
Post 6 of 6
10-22-2014 06:06 AM in reply to: jd239
we´ve the same problem over here in an Educational Environment with the roaming profiles of the students, but only with AutoCAD Architecture, and only with version 2015, all other previous versions over the last years since 2010 are starting quick.
