I cant seem to download the free trial for Revit 2014, its working on my laptop but not on my PC. I downloaded the exe file from the website and open it and click run but then nothing happens.
I have also tried running the "setup" application in C drive (computer- System (C)- Autodesk - Autodesk_revit_2014 etc), when this happens the autodesk revit setup intialization comes up but also an error message saying (have also included picture):
"Communication Failure"
Download and instillation has been interrupted by lost connection between the Autodesk webiste and this computer. The most likely causes are:
-The instillaiton package was removed from the install location, which is not supported
-The Autodesk download website was closed manually or refreshed beforethe instaler launced
-A fire wall has blocked the network ports
Please address these issues if possible, return to the website, and then click Install Now, or use another download methoid: Download Now or Browser Download.
I have tried all of the above but to no avail, also checked space on Pc and have plenty, any help would be greatly appreciated!!
I am trying to install Revit on Parallels desktop in a Mac Book Pro and I have the same problem.
-The Autodesk download website was closed manually or refreshed before the instaler launced
Any other suggestion to solve this?
Hi there Philip,
When I try to use the ASK button nothing seems to happen.
Still needing help downloading the Revit 2014
Hi @dany_naice and @J_Joseph!
I just updated the outdated post to include a link to the proper Virtual Agent location.
Hi @joelforbes and welcome to the Autodesk Community!
Please, disable your firewall and anti-virus programs and download the software from our Virtual Agent linked here (click on Download Links, choose product and version).
Please accept as solution if my post fully resolves your issue, or reply with additional details if the problem persists.
Hit the down facing arrow on the right hand side of the ''install now'' it should give you a drop down and options. it worked for me 🙂
i downloaded the autodesk revit software 2014 now the problem is where is the icon of revit its no where .... kindly help
Hi @saadsazer!
Not sure if you were able to figure this one out but it sounds like the program did not install all the way which would explain why the icon is not showing up anywhere.
As a workaround to the Communication Failure error that can occur with Install Now, can you try utilizing the Browser Download option (also available in the Autodesk Virtual Agent) as a workaround?
I downloaded Revit 2014 student version for my 32bit pc at the work place. Works 100%. Though at Home I have very limited internet data so I cannot redownload the full 2.9GB + download. I copied the files over. Installed teh setup adn it works but then I get this similar error. Is there another way to Fix this or is downloading it again the only option?
Hi @BVisser,
In this case your best bet is to download again via an alternative method, specifically browser download from the Autodesk Virtual Agent.
