Installation & Licensing
Revit trial 2014 problem installing "communication failure"
32 REPLIES 32
Message 1 of 33
16704 Views, 32 Replies
I cant seem to download the free trial for Revit 2014, its working on my laptop but not on my PC. I downloaded the exe file from the website and open it and click run but then nothing happens.
I have also tried running the "setup" application in C drive (computer- System (C)- Autodesk - Autodesk_revit_2014 etc), when this happens the autodesk revit setup intialization comes up but also an error message saying (have also included picture):
"Communication Failure"
Download and instillation has been interrupted by lost connection between the Autodesk webiste and this computer. The most likely causes are:
-The instillaiton package was removed from the install location, which is not supported
-The Autodesk download website was closed manually or refreshed beforethe instaler launced
-A fire wall has blocked the network ports
Please address these issues if possible, return to the website, and then click Install Now, or use another download methoid: Download Now or Browser Download.
I have tried all of the above but to no avail, also checked space on Pc and have plenty, any help would be greatly appreciated!!
32 REPLIES 32
Message 2 of 33
philip.s
Hi Luke!
The simplest workaround in this case would be to utilize a different download method, specifically Browser Download. You can access most current + previous supported version Browser Download links (including the Product Design Suites) through our Virtual Agent.
Please accept as a solution if this fully resolves the issue, or reply with additional specifics if the problem persists.
Message 3 of 33
in reply to: philip.s
Same problem. One laptop has a failure to communicate.
Suggesting a different way to download the product (I've tried all of them, in many browsers) is not an acceptable answer for me.
Installs fine on mulitple desktops and laptops, without error.
This laptop has the same permissive settings settings as those desktops on the same network, using the same installer files.
Would love to resolve this asap. My guys need to produce and I now have a headache.
Message 4 of 33
philip.s
My apologies for the inconvenience Kris.
When you click on Install Now button and the small Setup.exe starts downloading, please ensure that you do not click anywhere else, refresh, and or close the web page as the installer needs data for the product which you have selected to Install, and navigating away from the web page disrupts this process. Once the _Setup.exe is downloaded and the installer has launched, then you can close/refresh/click anywhere on the web page.
You mentioned the other download methods, what sort of errors are you getting with the Browser Download?
Message 5 of 33
estudi323
Hi Philip,
Same problem lukecopley. I've tried download as you say:
Matt, our Virtual Assistant.
From Matt: Download and Installation  Software Download Links  I need to redownload my product
but only english version avaiable. My question is: Can I download spanish Revit free trial version?
Thank you
Message 6 of 33
I have the same problem with Revit LT Trial.
There is only one download method, "Install now"! I can't find any "Download now" or "Browser download".
Svesjo
Message 7 of 33
camilo.lemos
in reply to: estudi323
Hi estudi323,
Here is the download link for Revit 2014 Spanish.
Best regards,
Camilo Lemos
Message 8 of 33
camilo.lemos
Hi Svesjo,
As Philip menioned above, you can access most current + previous supported version Browser Download links of English version (including the Product Design Suites) through Matt, our Virtual Assistant.
From Matt: Download and Installation -> Software Download Links -> I need to redownload my product.
Best regards,
Camilo Lemos
Message 9 of 33
estudi323
in reply to: camilo.lemos
Thanks Camilo. Just one more question: Can I install Revit 2014 or another product 2014 in Windows Vista 64 bits SP2?
Thanks again
Message 10 of 33
camilo.lemos
Hi estudi323,
I'm afraid Revit 2014, along with the whole 2014 line of products, is not supported on Vista.
Here are the system requirements for Revit 2014.
You can easily find out what the requirements are for the products you wish to install by typing "[Product name] system requirements" in the search field:)
Best regards,
Camilo Lemos
Message 11 of 33
The Matt link doesn't work via the ASK button.
Is there a time period for this service? Like a Live Chat?
Otherwise, it is not working.
Attached is my error message on screen.
Please advice.
Message 12 of 33
camilo.lemos
Hi Lawrence and welcome to the Autodesk Community.
Please, disable your firewall and anti-virus programs before downloading from the Virtual Agent and keep them disabled during the download. This should resolve the error you've encountered.
Let me know if you need any additional help.
Camilo Lemos
Message 13 of 33
You've got to be kidding. I can't install 2014 on Vista Ultimate? Now I'm thoroughly frustrated. Really, really, really unhappy about this.
Message 14 of 33
DarrenP
Vista has been unsupported the past 2 years for most autodesk products
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=18424371
this is nothing new
DarrenP
Message 15 of 33
in reply to: DarrenP
A work-around for Inventor was posted in another thread. Revit's setup.ini file is not identical but I tried removing the pertinent section. It let me get into the installer but the installer eventually recognized the unsupported OS. ANyone know of any other work-arounds to get the installation completed? THanks.
Message 16 of 33
Hi, I have just joined and I am having problems trying to download the free trial version of Revit 2014.
I have downloaded the file, but got the same error as Lawrence Poon.
I went to Matt, but this does not work either.
How do I proceed?
I have temporary administrator rights on my pc for 1 day only. But I cannot disable firewalls, alter ini settings etc etc.
Tags (3)
Message 17 of 33
In my case the problem was that I was trying to install on a Vista Ultimate machine... and it turns out nothing prior to 7 is supported anymore. But the message doesn't tell you that! Very frustrating.
Message 18 of 33
Had the same problems. Finally found the link ... http://labs-download.autodesk.com/us/labs/argon/setup_revitlt.exe
Hit get started ... worked for me.
Message 19 of 33
I have installed revit 2014 on my pc, it works but all the options like new projet in construction or architecture and the families are missing.
Can you help me ? Thanks a lot.
Message 20 of 33
k_1219
If you are still experiencing the problem with the installation of Revit, you can try installing it via Internet Explorer and simply select the Run installation button instead of saving the installation file.
Administrator Productivity
