Hello, Autodesk!
Do I really need to install Revit Structure 2014 Update Release 1 before Revit Structure 2014 Update Release 2 ? See my build number in attachement, please. Thanks in advance!
Hi kudryavcevrm,
Welcome to Autodesk Community.
You will need Update 1 before installing Update 2. Please refer to this article for Revit Structure 2014 Update Release 2.
Quote:" Prior to installing the Update Release 2, please verify that you have already installed the First Customer Ship build of Autodesk Revit Structure 2014 (Build: 201310308_1515) or Update Release 1 for Autodesk Revit Structure 2014 (Build: 20130709_2115)."
You may also want to review the ReadMe file prior to installation.
Thank you.
Great thanks, Aaron!
I have been confused by phrase below from the same source :
Prior to installing the Update Release 2, please verify that you have already installed the First Customer Ship build of Autodesk Revit Structure 2014 (Build: 201310308_1515)...
My build number differ in 1 digit only with the build number above
