Installation & Licensing
Revit Structure 2012 get Building Design Suite Ultimate License
3 REPLIES 3
ChinhPham5730
253 Views, 3 Replies
We use Autodesk networking license ( Base on Revit 2015 Disk).
Why does  RevitSrtucture2012 get Autodesk Building Design Ultimate license .
Please help me to fix  it.
PTChinh
3 REPLIES 3
Wellcome to the community:)
When using netwrok licence you can open only one version at a time else 2012 or 2015.
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
DarrenP
in reply to: sureshchotrani
thats whats is called cascading
you cannot change it
if there are no Revit Structure licenses available it will grab the Building Design Suite licenses next
DarrenP
TravisNave
in reply to: DarrenP
The above gentlemen are correct.  All you could do is use an Options file to prevent that user from grabbing a BDSU license.
For eveything you could possibly want to know about the adskflex.opt Options file for FlexLM, please see my KB article here:
http://forums.autodesk.com/t5/Installation-Licensing/Managing-the-adskflex-opt-Options-File/td-p/307...
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
