We use Autodesk networking license ( Base on Revit 2015 Disk).
Why does RevitSrtucture2012 get Autodesk Building Design Ultimate license .
Please help me to fix it.
PTChinh
Wellcome to the community:)
When using netwrok licence you can open only one version at a time else 2012 or 2015.
thats whats is called cascading
you cannot change it
if there are no Revit Structure licenses available it will grab the Building Design Suite licenses next
DarrenP
The above gentlemen are correct. All you could do is use an Options file to prevent that user from grabbing a BDSU license.
For eveything you could possibly want to know about the adskflex.opt Options file for FlexLM, please see my KB article here:
http://forums.autodesk.com/t5/Installation-Licensing/Managing-the-adskflex-opt-Options-File/td-p/307...
Good Luck!
